Salta al contenuto principale
Google Pixel 5a Screen Adhesive Installation
Cosa ti serve
  1. Google Pixel 5a Screen Adhesive Installation, Remove adhesive residue from the frame: passo 1, immagine 1 di 3 Google Pixel 5a Screen Adhesive Installation, Remove adhesive residue from the frame: passo 1, immagine 2 di 3 Google Pixel 5a Screen Adhesive Installation, Remove adhesive residue from the frame: passo 1, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Peel off as much adhesive as you can with a pair of tweezers.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 5a Screen Adhesive Installation, Remove adhesive residue from the screen: passo 2, immagine 1 di 3 Google Pixel 5a Screen Adhesive Installation, Remove adhesive residue from the screen: passo 2, immagine 2 di 3 Google Pixel 5a Screen Adhesive Installation, Remove adhesive residue from the screen: passo 2, immagine 3 di 3
    • Repeat the previous step for the screen adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the screen.
    • Don't use isopropyl alcohol near the front camera bracket as it will loosen its adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 5a Screen Adhesive Installation, Align the adhesive: passo 3, immagine 1 di 1
    • Use the front camera and corners of the frame to correctly align the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 5a Screen Adhesive Installation, Prepare the adhesive: passo 4, immagine 1 di 1
    • Peel away the clear plastic lining to expose the frame side of the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 5a Screen Adhesive Installation, Apply the adhesive: passo 5, immagine 1 di 2 Google Pixel 5a Screen Adhesive Installation, Apply the adhesive: passo 5, immagine 2 di 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the front camera and corners to help align the adhesive during installation.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 5a Screen Adhesive Installation, Secure the adhesive to the frame: passo 6, immagine 1 di 2 Google Pixel 5a Screen Adhesive Installation, Secure the adhesive to the frame: passo 6, immagine 2 di 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 5a Screen Adhesive Installation, Peel away the outer plastic lining: passo 7, immagine 1 di 2 Google Pixel 5a Screen Adhesive Installation, Peel away the outer plastic lining: passo 7, immagine 2 di 2
    • Use your fingers to grasp the blue plastic lining near the center and peel it away from the phone.
    • This should leave a thin perimeter of adhesive still covered by blue plastic lining.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 5a Screen Adhesive Installation, Connect the screen: passo 8, immagine 1 di 2 Google Pixel 5a Screen Adhesive Installation, Connect the screen: passo 8, immagine 2 di 2
    • Follow the screen replacement guide in reverse order and connect the screen to your pixel.
    • Remember to reinstall the screen connector bracket.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 5a Screen Adhesive Installation, Peel away the remaining plastic lining: passo 9, immagine 1 di 2 Google Pixel 5a Screen Adhesive Installation, Peel away the remaining plastic lining: passo 9, immagine 2 di 2
    • Peel away the blue plastic lining to expose the perimeter adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 5a Screen Adhesive Installation, Position the screen: passo 10, immagine 1 di 3 Google Pixel 5a Screen Adhesive Installation, Position the screen: passo 10, immagine 2 di 3 Google Pixel 5a Screen Adhesive Installation, Position the screen: passo 10, immagine 3 di 3
    • Position the screen so it lays on the frame.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 5a Screen Adhesive Installation, Press down the screen corners: passo 11, immagine 1 di 2 Google Pixel 5a Screen Adhesive Installation, Press down the screen corners: passo 11, immagine 2 di 2
    • Press down the corners of the screen to secure them to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 5a Screen Adhesive Installation, Secure the screen to the frame: passo 12, immagine 1 di 3 Google Pixel 5a Screen Adhesive Installation, Secure the screen to the frame: passo 12, immagine 2 di 3 Google Pixel 5a Screen Adhesive Installation, Secure the screen to the frame: passo 12, immagine 3 di 3
    • Press down on the edges of the screen.
    • Slide along the perimeter to secure it to the frame.
    • You can heat the perimeter of the screen to soften the adhesive and help it bond more securely.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 5a Answers community for help.
Altre 19 persone hanno completato questa guida.
Chayton Ritter
Membro da: 08/21/20
26.848 Reputazione
105 guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
17.856 guide realizzate
5Commenti sulla guida
Pretty easy. Maybe 20 mins job. Nice guide.
Toby Phillippe - Rispondi Condividi
What is the stack of books for?
ccc - Rispondi Condividi
Hey there!
Usually you would place a stack of books or 2L+ bottle of water on top of the device to apply extra force to the adhesive and leave it for some time, like 30-60 minutes. That would ensure better adhesion for the replacement screen. It is not necessary nowadays, but it's an old-school style way of gluing things together and seasoned repair techs still place something heavy on top of the device when replacing glued-in components
Nastya Grifon - Rispondi Condividi
Excellent instructions. I was able to get through this no problem.
Chrystian - Rispondi Condividi
Bought the kit and followed this guide, worked perfectly. Thanks Ifixit for helping me fix my phone.
David Helton - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 68
Tutti i Tempi: 8,439
