Salta al contenuto principale
Google Pixel 10a Loudspeaker Replacement
Cosa ti serve
  1. Google Pixel 10a Loudspeaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your Pixel.
    • If your rear cover is bulging, your battery may be swollen—take appropriate precautions.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 10a Loudspeaker Replacement, Eject the SIM card tray: passo 2, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Eject the SIM card tray: passo 2, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Eject the SIM card tray: passo 2, immagine 3 di 3
    • Insert a SIM card eject tool or a straightened paper clip into the small hole in the SIM card tray.
    • Press firmly to eject the tray.
    • Remove the tray.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 10a Loudspeaker Replacement, Heat the rear cover: passo 3, immagine 1 di 1
    • The rear cover is secured by mild adhesive. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover until it's hot to the touch.
    • For best practices on using a hair dryer to soften adhesive, check out this guide.
    • Alternatively, follow this guide if you're using an iOpener to heat the edge.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 10a Loudspeaker Replacement, Create an opening gap: passo 4, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Create an opening gap: passo 4, immagine 2 di 2
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 10a Loudspeaker Replacement: passo 5, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 5, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 5, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • If you're having trouble, reheat the edge and try again.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 10a Loudspeaker Replacement, Adhesive information: passo 6, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Adhesive information: passo 6, immagine 2 di 2
    • The rear cover is secured with adhesive around the frame perimeter and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 10a Loudspeaker Replacement, Separate the rear cover: passo 7, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Separate the rear cover: passo 7, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Separate the rear cover: passo 7, immagine 3 di 3
    • Slide the opening pick around the entire perimeter to separate the adhesive.
    • If you're having trouble separating the adhesive, apply more heat and try again.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 10a Loudspeaker Replacement: passo 8, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 8, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 8, immagine 3 di 3
    • Insert the opening pick deeper near the top-left corner and pry to separate the adhesive around the camera bezel.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 10a Loudspeaker Replacement: passo 9, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 9, immagine 2 di 2
    • Slowly peel up and remove the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 10a Loudspeaker Replacement, Remove the wireless charging assembly screws: passo 10, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Remove the wireless charging assembly screws: passo 10, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Magnetic Project Mat
    $16.96
    • Use a Torx Plus 3IP screwdriver to remove the fifteen 5.0 mm‑long screws securing the wireless charging assembly:
    • Thirteen gray screws
    • Two silver non-magnetic screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 10a Loudspeaker Replacement, Unclip the wireless charging assembly: passo 11, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Unclip the wireless charging assembly: passo 11, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Unclip the wireless charging assembly: passo 11, immagine 3 di 3
    • Use an opening pick to pry up and unclip the wireless charging assembly from the two cutouts—one near the bottom-right corner, and another on the left edge near the power button.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 10a Loudspeaker Replacement, Remove the wireless charging assembly: passo 12, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Remove the wireless charging assembly: passo 12, immagine 2 di 2
    • Remove the wireless charging assembly.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 10a Loudspeaker Replacement, Remove the battery connector cover: passo 13, immagine 1 di 1
    • Use a Torx Plus 3IP screwdriver to remove the 1.9 mm‑long screw securing the battery connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 10a Loudspeaker Replacement: passo 14, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 14, immagine 2 di 2
    • Remove the battery connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 10a Loudspeaker Replacement, Disconnect the battery: passo 15, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Disconnect the battery: passo 15, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Disconnect the battery: passo 15, immagine 3 di 3
    • Insert the point of a spudger under the top-right corner of the battery connector.
    • Pry up to disconnect the battery.
    • Throughout the repair, pry only at the instructed area (also marked by a gold line on the circuit board) to prevent damage to the delicate components near the connector socket.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 10a Loudspeaker Replacement, Disconnect the front camera: passo 16, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Disconnect the front camera: passo 16, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Disconnect the front camera: passo 16, immagine 3 di 3
    • Insert the point of a spudger under the top-left corner of the front camera connector and pry up to disconnect it.
    • Flip the camera module out of its recess and onto the logic board, making sure not to tear the copper foil.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 10a Loudspeaker Replacement, Remove the logic board screws: passo 17, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Remove the logic board screws: passo 17, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.9 mm‑long screws securing the logic board:
    • One at the top near the front camera
    • One near the bottom-right corner
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 10a Loudspeaker Replacement, Remove the logic board: passo 18, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Remove the logic board: passo 18, immagine 2 di 2
    • Insert the point of a spudger under the logic board near the front camera and pry up to loosen the board.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 10a Loudspeaker Replacement: passo 19, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 19, immagine 2 di 2
    • Make sure you've ejected the SIM card tray.
    • Insert the point of a spudger in the notch at the bottom-right corner of the logic board and pry up to loosen the board.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 10a Loudspeaker Replacement: passo 20, immagine 1 di 1
    • Bend the battery connector away from the logic board so it won't catch when you remove the board.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 10a Loudspeaker Replacement: passo 21, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 21, immagine 2 di 2
    • Use your fingers to carefully lift and remove the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 10a Loudspeaker Replacement, Remove the loudspeaker: passo 22, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Remove the loudspeaker: passo 22, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Remove the loudspeaker: passo 22, immagine 3 di 3
    • Use the point of an opening pick to pry up the top edge of the loudspeaker.
    • Remove the loudspeaker.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 10a Loudspeaker Replacement, Disassembly complete: passo 23, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 10a Loudspeaker Replacement, Install the loudspeaker: passo 24, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Install the loudspeaker: passo 24, immagine 2 di 2
    • Lay the loudspeaker in place at a shallow angle and guide the gasket into its cutout.
    • Press down firmly on the loudspeaker until it clicks into place.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 10a Loudspeaker Replacement, Logic board connector information: passo 25, immagine 1 di 1
    • The screen attaches to the underside of the logic board by a press connector, which you'll indirectly connect as you install the board. Follow the next few steps carefully to ensure this connects properly.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 10a Loudspeaker Replacement, Install the logic board: passo 26, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Install the logic board: passo 26, immagine 2 di 2
    • Insert the bottom edge of the logic board at a shallow angle into the frame so the USB-C port presses snugly against its frame cutout.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 10a Loudspeaker Replacement: passo 27, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 27, immagine 2 di 2
    • Use your finger to press the logic board near the USB-C port until you feel the board click in place.
    • If you're having trouble, try realigning the logic board so it presses snugly against the frame.
    • The logic board should fully seat against the plastic alignment pin.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 10a Loudspeaker Replacement: passo 28, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 28, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 28, immagine 3 di 3
    • Bend the battery connector out of the way so it won't be trapped under the logic board.
    • Lay the top part of the logic board in its recess.
    • Use the point of a spudger to help shift the rear cameras into their cutouts.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 10a Loudspeaker Replacement, Install the logic board screws: passo 29, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Install the logic board screws: passo 29, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to install the two 2.9 mm‑long logic board screws:
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 10a Loudspeaker Replacement, Install the front camera: passo 30, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Install the front camera: passo 30, immagine 2 di 2
    • Use a spudger or your finger to align and press the front camera into its cutout.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 10a Loudspeaker Replacement: passo 31, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 31, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 10a Loudspeaker Replacement, Connect the battery: passo 32, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Connect the battery: passo 32, immagine 2 di 2
    • Use your finger to align and press the battery press connector over its socket.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 10a Loudspeaker Replacement, Install the battery connector cover: passo 33, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Install the battery connector cover: passo 33, immagine 2 di 2
    • Hook the left edge of the battery connector cover in place, then lay the cover down flat.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 10a Loudspeaker Replacement: passo 34, immagine 1 di 1
    • Use a Torx Plus 3IP screwdriver to install the 1.9 mm‑long battery connector cover screw.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel 10a Loudspeaker Replacement, Install the wireless charging assembly: passo 35, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Install the wireless charging assembly: passo 35, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Install the wireless charging assembly: passo 35, immagine 3 di 3
    • Lay the wireless charging assembly onto the frame.
    • Use your fingers to press around the perimeter to engage all of its clips.
    • Stop if the assembly feels like it won't clip in. Check if anything underneath it may be out of place.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel 10a Loudspeaker Replacement: passo 36, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 36, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to install the fifteen 5.0 mm‑long wireless charging assembly screws:
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel 10a Loudspeaker Replacement, Test your repair: passo 37, immagine 1 di 1
    • Now is a good time to test your repair:
    • Power on your phone and check all functions.
    • Run a diagnostics test with the built-in Pixel Diagnostic tool.
    • If the screen or fingerprint sensor doesn't work correctly, you may need to reconnect the screen connector.
    • Fully power off your phone before you continue with reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  38. Google Pixel 10a Loudspeaker Replacement, Clean the frame: passo 38, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Clean the frame: passo 38, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Clean the frame: passo 38, immagine 3 di 3
    • Take your time cleaning the frame. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    • Use your fingers, spudger, or tweezers to remove the adhesive from the frame perimeter.
    • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
    • Use some high concentration (>90%) isopropyl alcohol and a lint-free cloth (or coffee filter) to remove any adhesive residue.
    Chiedi a FixBot
    Aggiungi Commento
  39. Google Pixel 10a Loudspeaker Replacement, Replace the camera bezel adhesive: passo 39, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Replace the camera bezel adhesive: passo 39, immagine 2 di 2
    • Inspect the adhesive blocks surrounding the rear cameras. If they're clean and unwrinkled, you can reuse them and skip down three steps.
    • Use the point of a spudger to pry up and remove the seven adhesive blocks surrounding the rear cameras.
    Chiedi a FixBot
    Aggiungi Commento
  40. Google Pixel 10a Loudspeaker Replacement: passo 40, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 40, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 40, immagine 3 di 3
    • Peel the clear liner from the camera bezel adhesive.
    • Carefully align and lay the adhesive in place. Use the rear cameras to help with alignment.
    Chiedi a FixBot
    Aggiungi Commento
  41. Google Pixel 10a Loudspeaker Replacement: passo 41, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 41, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 41, immagine 3 di 3
    • Use your fingers to press the camera bezel adhesive onto the frame.
    • Peel and remove the top blue liner from the adhesive.
    • There will still be a thin liner covering the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  42. Google Pixel 10a Loudspeaker Replacement, Replace the rear cover interior adhesive: passo 42, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Replace the rear cover interior adhesive: passo 42, immagine 2 di 2
    • Inspect the interior adhesive blocks on the rear cover. If they're clean and unwrinkled, you can reuse them and skip down two steps.
    • Use a spudger to scrape and remove the interior adhesive blocks from the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  43. Google Pixel 10a Loudspeaker Replacement: passo 43, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 43, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 43, immagine 3 di 3
    • Peel the clear liner from the interior adhesive sheet.
    • Align and press the adhesive onto the rear cover. Use the camera cutout to help with alignment.
    • Slowly peel and remove the large liner.
    Chiedi a FixBot
    Aggiungi Commento
  44. Google Pixel 10a Loudspeaker Replacement, Install the rear cover adhesive: passo 44, immagine 1 di 1
    • Without peeling any liners, hold the rear cover adhesive over the phone to figure out how it'll sit on the frame. Use the camera cutout to help with orientation.
    Chiedi a FixBot
    Aggiungi Commento
  45. Google Pixel 10a Loudspeaker Replacement: passo 45, immagine 1 di 1
    • Peel down the top half of the clear liner to expose the adhesive—don't fully remove the liner yet.
    Chiedi a FixBot
    Aggiungi Commento
  46. Google Pixel 10a Loudspeaker Replacement: passo 46, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement: passo 46, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement: passo 46, immagine 3 di 3
    • Take your time aligning the adhesive to the frame. If you apply it incorrectly, you'll need to restart with new adhesive.
    • Align and lay the top edge of the adhesive onto the frame.
    • Press down along the top edge to secure the alignment.
    • Slowly peel away the clear liner as you press the rest of the adhesive in place.
    Chiedi a FixBot
    Aggiungi Commento
  47. Google Pixel 10a Loudspeaker Replacement: passo 47, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 47, immagine 2 di 2
    • Use a spudger to press the adhesive onto the entire frame perimeter.
    Chiedi a FixBot
    Aggiungi Commento
  48. Google Pixel 10a Loudspeaker Replacement: passo 48, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement: passo 48, immagine 2 di 2
    • Peel up and remove the large liner from the rear cover adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  49. Google Pixel 10a Loudspeaker Replacement: passo 49, immagine 1 di 1
    • If you installed replacement camera bezel adhesive, remove all remaining liners from it.
    Chiedi a FixBot
    Aggiungi Commento
  50. Google Pixel 10a Loudspeaker Replacement: passo 50, immagine 1 di 1
    • Remove the perimeter adhesive liner.
    • Carefully inspect the frame for any remaining liners and remove them.
    Chiedi a FixBot
    Aggiungi Commento
  51. Google Pixel 10a Loudspeaker Replacement, Inspect the rear camera glass: passo 51, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Inspect the rear camera glass: passo 51, immagine 2 di 2
    • Make sure the rear cover camera cutouts are clean. Carefully wipe them with a lint-free cloth if needed.
    • Remove any lens caps or liners from the rear cameras. Make sure the lenses are clean. Gently wipe them with a lint-free cloth if needed.
    Chiedi a FixBot
    Aggiungi Commento
  52. Google Pixel 10a Loudspeaker Replacement, Install the rear cover: passo 52, immagine 1 di 3 Google Pixel 10a Loudspeaker Replacement, Install the rear cover: passo 52, immagine 2 di 3 Google Pixel 10a Loudspeaker Replacement, Install the rear cover: passo 52, immagine 3 di 3
    • Lay the rear cover over the frame.
    • Firmly press around the perimeter to secure the adhesive.
    • You can also hold your phone and squeeze firmly around the perimeter to strengthen the adhesive bond.
    • For an even more secure bond, lay your phone screen-down on a clean and flat surface underneath a few books overnight.
    Chiedi a FixBot
    Aggiungi Commento
  53. Google Pixel 10a Loudspeaker Replacement, Insert the SIM card tray: passo 53, immagine 1 di 2 Google Pixel 10a Loudspeaker Replacement, Insert the SIM card tray: passo 53, immagine 2 di 2
    • Insert the SIM card tray into its slot on the Pixel.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Arthur Shi
Membro da: 01/03/18
336.967 Reputazione
849 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 60
Tutti i Tempi: 154
