Salta al contenuto principale
Fairphone 5 Screen Replacement
Cosa ti serve
  1. Fairphone 5 Screen Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 1
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fairphone 5 Screen Replacement, Pry up the back cover: passo 2, immagine 1 di 2 Fairphone 5 Screen Replacement, Pry up the back cover: passo 2, immagine 2 di 2
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fairphone 5 Screen Replacement, Remove the back cover: passo 3, immagine 1 di 3 Fairphone 5 Screen Replacement, Remove the back cover: passo 3, immagine 2 di 3 Fairphone 5 Screen Replacement, Remove the back cover: passo 3, immagine 3 di 3
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fairphone 5 Screen Replacement, Remove the battery: passo 4, immagine 1 di 3 Fairphone 5 Screen Replacement, Remove the battery: passo 4, immagine 2 di 3 Fairphone 5 Screen Replacement, Remove the battery: passo 4, immagine 3 di 3
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Fairphone 5 Screen Replacement, Unfasten the screen: passo 5, immagine 1 di 2 Fairphone 5 Screen Replacement, Unfasten the screen: passo 5, immagine 2 di 2
    • Use a Phillips driver to remove the eight 3.9 mm‑long screws securing the screen.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fairphone 5 Screen Replacement, Reposition the screen: passo 6, immagine 1 di 3 Fairphone 5 Screen Replacement, Reposition the screen: passo 6, immagine 2 di 3 Fairphone 5 Screen Replacement, Reposition the screen: passo 6, immagine 3 di 3
    • While supporting the screen, lift the phone with the screen facing downward.
    • Pull the phone frame upward to separate it from the screen.
    • Flip the screen and frame over and lay them down with the screen resting over the top left portion of the frame, exposing the display cable.
    • Don't strain the cable. You only need enough space to access the screen press connector.
    Chiedi a FixBot
    Aggiungi Commento
  7. Fairphone 5 Screen Replacement, Remove the screen: passo 7, immagine 1 di 3 Fairphone 5 Screen Replacement, Remove the screen: passo 7, immagine 2 di 3 Fairphone 5 Screen Replacement, Remove the screen: passo 7, immagine 3 di 3
    • Use the point of a spudger to pry up and disconnect the screen press connector.
    • Remove the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
245.389 Reputazione
1.203 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
31.535 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 66
Ultimi 30 giorni: 284
Tutti i Tempi: 8,205
