Salta al contenuto principale
kobo glo ereader Screen Replacement
Ismail Esen
Ismail Esen e un altro collaboratore
Ultimo aggiornamento il October 27, 2020
30 minuti
Facile
Guida fornita dalla comunità
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. kobo glo ereader Screen Replacement, Remove Back Cover: passo 1, immagine 1 di 1
    • Pry the back cover off just below the grey belt between the screen and back cover. No screws. Be careful not to lose the sliding power button while you are removing the back cover.
  2. kobo glo ereader Screen Replacement, Disconnect screen cables.: passo 2, immagine 1 di 3 kobo glo ereader Screen Replacement, Disconnect screen cables.: passo 2, immagine 2 di 3 kobo glo ereader Screen Replacement, Disconnect screen cables.: passo 2, immagine 3 di 3
    • Gently pull out these 3 cables to disconnect the screen.
  3. kobo glo ereader Screen Replacement, Remove Screen and Install new one.: passo 3, immagine 1 di 1
    • Pry the screen off the middle layer; screen is also attached by adhesive tapes. You can keep them intact for the new screen. Once screen is removed. Put on the new screen and connect the cables. Then put on the back cover. Be careful not to lose the power button.
Conclusione
To install the new screen, connect the cables first and then install the screen onto the middle panel. Then install the back panel.
Ismail Esen
Membro da: 06/08/20
97 Reputazione
1 Guida realizzata
7Commenti sulla guida
I appreciate that this guide exists, but could you specify which screws to remove? What size are they? And most importantly, what's the screen number? I can't find it on Amazon at all.
Thank you for your efforts.
Soma Schicksal - Replica
Hey, it’s been some time but as I remember you do not need to remove any screws (as per the post). You just need to unplug the screen cable.
As per the screen itself, the part might have gone from Amazon or the part number changed. Maybe Ebay or AliBaba would have it?
Ismail Esen -
I have replaced the screen, it's now as easy as you explained. The double sided tape used was very hard to take out. But alas, it works now.
Glad that it was helpful!
Ismail Esen -
is this guide for kobo glo or kobo glo hd ?
Eric Van Buggenhaut - Replica
It's for Kobo Glo, not the HD version.
Ismail Esen -
Hi, the images show a Kobo Glo HD, so the guide is misattributed.
The essential process for the Kobo Glo is similar enough however, with the difference being that it has a glued in recessed screen, which means you need to push the screen out from the front along with the rear assembly.
The guide also fails to mention 4 PH000 screws that hold the rear assembly - these need unscrewing once the back cover is off. They're all easy to spot.
For anyone wondering about the part number, the Kobo Glo (non-HD) runs a screen with the part number ED060XG1.
veedwood - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 167
Tutti i Tempi: 5,402
