Salta al contenuto principale
iRulu AX760 Camera Replacement
Jamison Kritz
Jamison Kritz e un altro collaboratore
Ultimo aggiornamento il February 10, 2019
5 minuti
Difficile
Introduzione
Vai al passo 1
This guide will teach you how to disconnect the camera of your iRulu AX760 and remove it from the device. You will learn how to disconnect digitizer ribbons in this replacement process.
Cosa ti serve
Strumenti
  1. iRulu AX760 Camera Replacement, Battery: passo 1, immagine 1 di 3 iRulu AX760 Camera Replacement, Battery: passo 1, immagine 2 di 3 iRulu AX760 Camera Replacement, Battery: passo 1, immagine 3 di 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Camera Replacement: passo 2, immagine 1 di 1
    • Open your tablet.
  3. iRulu AX760 Camera Replacement: passo 3, immagine 1 di 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Camera Replacement: passo 4, immagine 1 di 2 iRulu AX760 Camera Replacement: passo 4, immagine 2 di 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Come saldare e dissaldare componenti elettrici
  5. iRulu AX760 Camera Replacement: passo 5, immagine 1 di 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Camera Replacement, Camera: passo 6, immagine 1 di 2 iRulu AX760 Camera Replacement, Camera: passo 6, immagine 2 di 2
    • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
  7. iRulu AX760 Camera Replacement: passo 7, immagine 1 di 1
    • Pull the digitizer ribbon cables straight out of their sockets.
  8. iRulu AX760 Camera Replacement: passo 8, immagine 1 di 1
    • Pull the camera out of the device.
Conclusione
Jamison Kritz
Membro da: 03/20/18
245 Reputazione
2 Guide realizzate
IUPUI, Team S6-G4, Baechle Spring 2018 Membro di IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 125
