Salta al contenuto principale
iRobot Roomba 692 Motherboard Replacement
Ruth Oliva
Ruth Oliva e 3 altri collaboratori
Ultimo aggiornamento il December 18, 2023
30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will teach you how to access, remove, and replace your iRobot Roomba 692 motherboard. If you are replacing the motherboard, ensure that you have the right motherboard for the Roomba 692 prior to removal.
Remember to review the iRobot Roomba 692 Troubleshooting Page before attempting any maintenance or repairs on your vacuum.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. iRobot Roomba 692 Motherboard Replacement, Battery: passo 1, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement, Battery: passo 1, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Motherboard Replacement: passo 2, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement: passo 2, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Motherboard Replacement: passo 3, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement: passo 3, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement: passo 3, immagine 3 di 3
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove the ten 13.3 mm screws with a Phillips #00 screwdriver.
    • Pull off the outer and inner holders.
  5. iRobot Roomba 692 Motherboard Replacement: passo 5, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement: passo 5, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement: passo 5, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the two 7.4 mm screws that secure the sensor.
    • Once screws are removed slide out the sensor to free it from the slide bumper.
  6. iRobot Roomba 692 Motherboard Replacement: passo 6, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement: passo 6, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement: passo 6, immagine 3 di 3
    • Wedge open the top with an opening tool.
    • Wedge the side tabs and middle tabs upward to remove the top lid.
  7. iRobot Roomba 692 Motherboard Replacement: passo 7, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement: passo 7, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #00 screwdriver to unscrew and remove the following screws:
    • Ten 9.6 mm screws.
    • Four 9.4 mm screws.
    • One 9.5 mm screw.
  8. iRobot Roomba 692 Motherboard Replacement: passo 8, immagine 1 di 3 iRobot Roomba 692 Motherboard Replacement: passo 8, immagine 2 di 3 iRobot Roomba 692 Motherboard Replacement: passo 8, immagine 3 di 3
    • Lift up the top cover to access the motherboard.
    • Use the Phillips #00 screwdriver to remove all five 7.6 mm screws that are holding it down.
  9. iRobot Roomba 692 Motherboard Replacement: passo 9, immagine 1 di 2 iRobot Roomba 692 Motherboard Replacement: passo 9, immagine 2 di 2
    • Unplug the wiring by pulling it outward.
    • Once all plugs are off the motherboard it can be removed, repaired, or replaced.
Conclusione
Ruth Oliva
Membro da: 11/08/23
217 Reputazione
2 Guide realizzate
IUPUI, Team 1-1, Harley Fall 2023 Membro di IUPUI, Team 1-1, Harley Fall 2023
IUPUI-HARLEY-F23S1G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 278
