Salta al contenuto principale
iRobot Roomba 4100 Battery Pack Replacement
Scott Leonard
Scott Leonard e 13 altri collaboratori
Ultimo aggiornamento il January 28, 2022
1 - 2 minuti
Molto facile
Introduzione
Vai al passo 1
This guide explains how to replace the iRobot Roomba 4100 battery by giving you the necessary instructions. The Roomba battery may need to be replaced if your Roomba will no longer charge or if the Roomba no longer powers on. Depending on the amount of use of the Roomba, you may need to replace the Roomba if power issues are consistent and are not fixed with a simple battery replacement. Replacing the iRobot Roomba 4100 battery will solve the power issues and allow your Roomba a stronger and longer lasting charge. To repair your iRobot Roomba 4100 battery their are no special skills or prior knowledge needed. The battery is a vital part of the Roomba, and for it to be operational the battery should be in good condition for proper function.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. iRobot Roomba 4100 Battery Pack Replacement: passo 2, immagine 1 di 2 iRobot Roomba 4100 Battery Pack Replacement: passo 2, immagine 2 di 2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. iRobot Roomba 4100 Battery Pack Replacement: passo 3, immagine 1 di 1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
Conclusione
Your iRobot Roomba 4100 is now ready for use.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 20-6, Maness Fall 2010 Membro di Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 8,467
