Salta al contenuto principale
iPod 5th Generation (Video) Click Wheel Button Replacement
Miroslav Djuric
Miroslav Djuric e un altro collaboratore
Ultimo aggiornamento il 13 ott 2025
Nessuna stima
Moderato
Introduzione
Vai al passo 1
This guide shows how to remove the click wheel button from an iPod Video.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. iPod 5th Generation (Video) Click Wheel Button Replacement, Case: passo 1, immagine 1 di 1
    • Before opening your iPod, ensure that the hold switch is in the locked position. The slider should be all the way to the right if your iPod is facing you, screen-side down.
    One word of advice: My cousin opened his vid from the top and accidentally cracked his screen in half. I would suggest to start opening it from the bottom, near the dock connector.
    Cyrus - Replica
    I too just cracked the screen in half by starting at the top. The screen is completely shot now. Got a guide for replacing screens? These things are hard to open. Be careful! Have someone hold it while you slowly pry it open.
    wittweb - Replica
    I have a cracked screen, starting from the upper right corner. 1/3 ofthe screen is black. Can I fix it?
    Phil
    koby -
    I just replaced a broken screen and battery tonight in my early ipod video 30g. I think you may have not got the audio cable back in correctly or you may need to replace the earphone connector. This site is great and just last week i used ifixit parts to fix my ibook dc in then tonight my ipod. Saved a ton of cash and the service is awesome.
    spdmonkey - Replica
    ive just replaced my screen and its working fine, apart from when i switch it on it says i need to connect to itunes, when i do that it says that it needs resetting to factory settings, and when i do that it gets to the end then just says i need to reset it again???? any help please?
    qwerty - Replica
    me too hav the same prob.. :D
    nadhil muhammed -
    Replaced my screen that somehow cracked in my bag while it was under the seat in front of me on an airplane. 80GB 5.5g video.
    The only thing I'll add is that when I first installed the new screen, I would get all kinds of weird artifacts after putting the case back together. It would be fine with the case open but as soon as pressure was applied it would turn white and go crazy. I looked at the old screen and saw a small white plastic sticker covering the electronics on the old screens ribbon cable, so I peeled it off and put it on the new screen's ribbon cable and everything went back together and worked perfectly. Placing pressure on these components must cause trouble and I guess the sticker disperses the pressure to prevent this. It's like new.
    I was really bummed because I have Rockbox running on this thing and no ipods since the 5.5g will run it, and you can't buy those anymore without spending a fortune. Thank you ifixit.com.
    gkmeyer - Replica
    i followed all the steps and fix it up by myself ~ haha THX~
    swean - Replica
    Citazione da hidi00z:
    hey, greg29 i have the same situation with my 5th gene iPOD, right now the display it's white and i want to know if you show where i need to put the white sticker or another kind of sticker because the old dispelay i throw it away...thanks,
    hidi00z - Replica
    Just finished replacing my battery (30 gb video). Piece of cake! Great information. I would skip steps 7-9, and just replace battery. But I'm no expert....
    Gino T - Replica
    I need a little help guys. I have an Ipod 30G video that I plugged into a car charger and now the screen is black with the apple logo. I thought it was the battery that was dead, but I replaced it using your guide(thanks!!) and it's still showing the same thing. Black screen with the apple logo. I tried charging it and it still doesn't do anything. Any ideas what it could be? Thanks.
    jer - Replica
    Replaced battery and screen on 30GB video ipod in 90 minutes. In the first 5 minutes the fine tip broke off the removal tool. Later I discovered why....I was prying the front cover off instead of separarting the back cover from the rest of the unit. The front cover tabs are right next to the back cover tabs so be sure you are getting the right one. If done properly I would have saved 30 minutes. I also broke several front cover tabs during removal so good thing I was replacing front cover too! The new front cover did not match up well with the old tabs. I agree with skipping steps 7 - 9 to release the headphone ribbon. I yanked the unit around pretty good getting the front cover back on and no trouble with the headphones. The removal tools were no match for the tape on the back of battery, instead get a very small standard screwdriver to get the battery loose. Trickiest part is the little tab that holds the battery ribbon; when you are putting it back together just push straight down nice and easy with the tip of the small tool and she locks right back in place. The wife had given up on this iPod and get a new 8 GB nano for Christmas...I inherited this one and am quite pleased for $30! iTunes did not pop up when I hooked it to the USB to charge, so I that I will go now and see if there is problem there. Terrific site, thanks for the help.
    Jeff - Replica
    Citazione da stumped:
    I followed all the steps for taking apart my 5th gen Ipod video, replacing the factory battery with a new one. Now my click wheel does not work. I've tried resetting it without success. Any suggestions?
    I have exactly the same problem, though I was replacing the headphone jack instead. Nothing appears to be loose and I didn't open the front panel at all.
    benthuronyi - Replica
    Citazione da jimmora:
    Hi - no need to disconnect all those cables, take out the HD, etc. Skip all the way to unscrewing and save the effort of trying to sneak those cables back into place.
    well the cables aren't too bad, and you don't want to accidentally tear one of the cables when sliding in the new display-- i'd recommend disconnecting the hard drive, battery and headphone jack before attempting to remove the screen.
    iTronics Repair - Replica
    BRILLIANT instructions!
    I got software problem after installing new Logic Board. iTunes keeps asking me to restore - I do, but it make no difference. Still can't synch. Anyone else have this problem?
    jingofafa - Replica
    Citazione da jingofafa:
    terry cynright - Replica
    Citazione da benthuronyi:
    Yes, when I replaced my screen, the click wheel no longer works except I can hold the select & menu buttons and rest my i-pod all day long. that is the only part of the click wheel that now works. Anyone can help all 3 of us out?
    dragonlore - Replica
    Citazione da terry cynright:
    I found out the problem: I used the wrong Logic Board! I have a 5th Gen. 80GB model and needed the 820-1975-A board (instead I installed the 820-1763-A board, which apparently only works for 30 and 60 GB models).
    I wish I'd read this sooner: upgrading hard drive from 30 GB to 80 GB
    jingofafa - Replica
    I've just replaced the my battery too (30 GB Video). Though it was quite challenging to opening the iPod, it all went smoothly after that; except from a small incident when the small tool broke when attempting to remove the battery from the iPod back. I used the big one instead and it went all fine. I also skipped steps 7-9)
    CAUTION: when removing the battery from the iPod back panel, watch-out not to damage the "hold button cable" . The cable is right below the battery, and might be glued to it.
    I've connected the iPod to iTunes and everything is reacting fine. My iPod is recharging right now on its cradle :-)
    Total handling time: 45 min max.
    Thanks to everyone for the tips. Great web site!
    gioverking - Replica
    I'd check that the control cable is correctly seated in its ZIF socket. And that the hold switch is not on.
    Yishai Sered - Replica
    Citazione da Miroslav Djuric:
    Nice guide!
    It is a nice guide. I happened to have access to a #000 Phillips which I thought worked a little better than a #00. What do you think?
    pricemccarty - Replica
    just tryed to replace battery in my i pod but didnt work had to put old battery back in the cable seems to be backwards to the oiginal one now what
    saxconstruction - Replica
    Have you tried flipping the battery over?
    eggs -
    very informative
    Mike Chang - Replica
    If a simple diagram of the retaining clips and their locations on the device might be helpful.
    RJones - Replica
    The first step was the most difficult for me, as I nearly destroyed the wide opening tool sold by ifixit in the process... after wedging it slightly open, I then grabbed a screwdriver and pulled apart the rest of the iPod. On second thought if I remembered, the putty knife sold here would also help at the very beginning.
    Thanks ifixit!
    Raj Seshadri - Replica
    Excellent instructions! One suggestion was made to start at the bottom. The first step does show the tool used to start opening at the bottom; so, starting at the top contradicts the first step anyway. Am currently repairing a friends MBP, so have learned a lot about Apple's micro-technology. Patience is certainly a virtue here! : ) Thank you, iFixIt!! Jim W, Panama City, FL
    Jim - Replica
    This was a workout! This took me 75+ min.
    Very hard to open. Needed butter knife to work the crack begun by iPod opening tool (aka myFinger opening tool when it slips); would take forever with only the tool. Hard to sense when retaining clips release. Please use screws, Apple!
    Step 6: Really tricky to slide up the tiny brown connector latch without popping off either it or the tiny white logic board connector. So delicate! I popped off both. Argh! By God's grace, nothing broke, and I got it all back together.
    Steps 7-9: Skipped, and glad I did, given #6; just be careful not to over-twist ribbon cable joining case & face..
    Step 10: Don't pry out battery looking from same angle as in photo; turn 180 degrees so you can see what's under battery, where to pry or not. I pried with small screwdriver; plastic tool is wrong shape. Apply leverage sensitively; peel headphone ribbon cable off adhesive as you go … slowly. I left some paper on adhesive so cable wouldn't adhere again.
    But success. Thanks, iFixit.
    Gyandev - Replica
    I was doing great until I pulled the battery connector off the board. I guess that's game over. Darn! I'm really just trying to rescue someone's music. Does anyone know if there's a way to connect the hard drive to a Mac and access the contents without a functional iPod?
    Mike Rosenberg - Replica
    Well, I found external USB cases on Amazon and eBay for the 1.8" ZIF hard drive, so I know it's possible to use the iPod's drive as an external drive. I just don't know whether it's formatted in a way I can access the music.
    Mike Rosenberg -
    Hello,
    I think it’s easier if you open it by a side. It took me less than 20s, and from the bottom i can’t.
    aurelien.engerer - Replica
  2. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 2, immagine 1 di 1
    • Opening the iPod can be challenging. Do not get discouraged if it takes you a few tries before the iPod is opened.
    • Free the first retainer clip on the bottom of the iPod using the iPod opening tool. The tool's edge should point towards the metal back case to prevent scratching the plastic front.
  3. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 3, immagine 1 di 1
    • Use this photo of the OPENED iPod for the reference, in order to locate the areas where the retaining clips are - 4 per side, one on top and two at the bottom. It should save you a lot of frustration and help avoid scratching the plastic cover.
  4. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 4, immagine 1 di 3 iPod 5th Generation (Video) Click Wheel Button Replacement: passo 4, immagine 2 di 3 iPod 5th Generation (Video) Click Wheel Button Replacement: passo 4, immagine 3 di 3
    • There are four retaining clips on each side of the iPod. An iPod opening tool will be used to separate the plastic front from the metal back of the iPod.
    • Insert the iPod opening tool into the left side of the iPod, with the edge of the tool pointing towards the metal back.
    • A small guitar pick can be extremely helpful in opening the iPod. Simply insert it and slide the pick around the case to free the clips to streamline the process.
    • Gently enlarge the existing crevice by wiggling the iPod opening tool and moving it to the left.
    • Continue doing so until the entire side of the iPod is loose.
    • You can then insert an iPod opening tool to the right of the Hold button. Be very careful while inserting the tool, as the display is very fragile.
  5. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 5, immagine 1 di 2 iPod 5th Generation (Video) Click Wheel Button Replacement: passo 5, immagine 2 di 2
    • Gently glide the iPod opening tool on the top of the display, making sure to free the retaining clips.
    • The other sides of the iPod should now easily come loose. If they do not, use iPod opening tools on the right side of the iPod in the same way as on the left side of the iPod.
    • Separate the front of the iPod from the back about an inch (or a couple of centimeters).
    • The iPod casing is now open, but don't completely separate the two halves just yet. Two ribbon cables are still connecting the back panel to the rest of the iPod.
  6. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 6, immagine 1 di 2 iPod 5th Generation (Video) Click Wheel Button Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    $3.99
    • Use angled tweezers or an iPod opening tool to slide up the brown connector latch, holding the orange battery ribbon cable in place. Make sure you pull from both sides of the latch. You only need to lift the brown connector latch up about 1-2mm to free the cable. Do not lift more or remove the latch, or you might pull the white connector with it!
    • Don't lift up too far or you could pull the battery connector out of the logic board.
    • Make sure to slide the brown connector directly upwards. The connector is frail and will break if it is accidentally shifted to the side. The connector has hooks at the bottom to hold the cable in place. As soon as you break one of the arms you will have problems putting the battery cable back on. If it breaks put the cable in the slot and then push the brown holder in place to keep the cable from slipping out.
    • Remove the cable from the connector.
  7. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 7, immagine 1 di 1
    • You should now have one orange ribbon cable still attaching the front case to the back.
    • At this point you are able to remove and replace the blue rubber bumpers, or continue with separating the case.
    • Separating the case is not necessary to complete battery replacement but may facilitate ease of replacement. It does require removing an extra cable at some risk of damage during removal.
  8. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 8, immagine 1 di 1
    • Lift up the hard drive to expose the headphone jack ribbon connector (indicated by the yellow box).
    • If the hard drive bumpers come loose, make sure to put them back with the notch as shown in the picture.
  9. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 9, immagine 1 di 2 iPod 5th Generation (Video) Click Wheel Button Replacement: passo 9, immagine 2 di 2
    • With the iPod opening tool, gently lift the brown tab of the headphone ribbon cable connector. The tab will rotate up 90 degrees, releasing the ribbon cable.
    • Using your fingers, pull out the headphone jack ribbon cable.
  10. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 10, immagine 1 di 1
    • The front and back of the iPod should now be completely separated.
  11. iPod 5th Generation (Video) Click Wheel Button Replacement, Hard Drive: passo 11, immagine 1 di 2 iPod 5th Generation (Video) Click Wheel Button Replacement, Hard Drive: passo 11, immagine 2 di 2
    • Use a small iPod opening tool to release the black hinge holding the hard drive ribbon cable. The tab will rotate up 90 degrees towards the logic board, releasing the ribbon cable.
    • Use your forefinger to hold the ribbon cable in place; disconnect the drive from the ribbon cable.
    • Make sure the hard drive rubber side bumpers are attached to the drive being installed. Use the hard drive rubber side bumper installation guide to accomplish this task.
    • If necessary, the blue foam padding on the hard drive might also need to be transferred to the replacement drive.
  12. iPod 5th Generation (Video) Click Wheel Button Replacement, Front Panel: passo 12, immagine 1 di 2 iPod 5th Generation (Video) Click Wheel Button Replacement, Front Panel: passo 12, immagine 2 di 2
    • Remove the three black Phillips screws securing the front panel to the metal framework.
    • Rotate the iPod laterally 180 degrees and remove the three black Phillips screws securing the front panel to the metal framework on the other side.
  13. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 13, immagine 1 di 2 iPod 5th Generation (Video) Click Wheel Button Replacement: passo 13, immagine 2 di 2
    • You may meet some resistance near the center of the iPod as there is a mild adhesive used to help hold the two pieces together.
    • Carefully work around the edge of the iPod to separate the front panel from the metal framework.
    • Lift the framework (including the attached display, logic board, and click wheel) away from the front panel.
    • Make sure that the click wheel button is in place before reinstalling the framework in the front panel.
  14. iPod 5th Generation (Video) Click Wheel Button Replacement: passo 14, immagine 1 di 1
    • The front panel should now be free from the rest of the iPod.
  15. iPod 5th Generation (Video) Click Wheel Button Replacement, Click Wheel Button: passo 15, immagine 1 di 1
    • Gently turn the iPod over to the other side. The click wheel button can now be removed from the rest of the iPod.
Conclusione
Altre 94 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
7Commenti sulla guida
very simple guide. really helps! I helped my dad fix his iPod!
Traiva - Replica
thanks i know my ipod is old but if you can buy replacement parts shoot im gonna keep it .
Justinian Pescador - Replica
Great guide! I had a “stuck” click wheel button, but taking it apart, I was able to find out that the tiny soft pad underneath the click wheel button plastic was simply off-center. All fixed!
Oscar - Replica
I had thesame problem like you,and i also got mine fixed.
njunki ebane -
Same here! That was a cheap repair!
Patrick Oltraver -
it is perfect,you helped me fix my stuck center wheel button.Thank you!!
njunki ebane - Replica
What about the little connector from the clicker wheel?
how or were do you atach it too ? The frame
Peter A - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 65
Ultimi 7 Giorni: 185
Ultimi 30 Giorni: 844
Tutti i Tempi: 73,470
