iPod 2nd Generation Battery Replacement
Introduzione
Vai al passo 1Battery not lasting long? Swap it out.
Cosa ti serve
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
The angle is important. I tried forever to get it started more like the photo, straight in between. No luck, seemed impossible. When I put the iPod down on a padded surface, held the top/white half with one hand, I was able to push "down" into the metal with the opening tool with relative ease. Popped right off without any great force. Then I was able to more closing match the remaining photos, circling around the other tabs holding it as pictured.
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
can be a little reluctant - DONT FORCE IT! gently pry the _entire_ contents out of the metal base at the dock-connector end. After which the headphone jack and lock switch will be free. Unlike newer models, there are no active components on the metal rear panel so no ribbon cables running between the two halves.
Altre 18 persone hanno completato questa guida.
2Commenti sulla guida
Nice easy fix. Modern batteries are twice the capacity too. These old gen iPods are great. Nice to have an apple product not made in China.
For my 2nd Generation iPod A1019 I found the batteries linked to at the beginning of this tutorial to be too thick to close the iPod without considerable force that actually seemed to bend and distort the display. Side by side they are nearly twice the thickness of the original battery. I bought both the 2200 mAh version, then also the 1600 mAh version hoping it would be thinner. All these batteries are manufactured by Cameron Sino. I am hoping to be able to find the actual Sony item and my search continues.
