iPhone 3GS Logic Board Replacement
Introduzione
Vai al passo 1The motherboard of your iPhone controls everything in the iPhone.
Cosa ti serve
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape, or thick, clear packing tape may be used.
Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
Is there a way of replacing the connector?
i have torn the top of the connector......... would that be the reason that the iPhone would not start even though the ribbon is in the connector and fastened secured with the white plastic tab is down.
I HAVE DONE IT. SO THANK YOU GUYS.
Citazione da Vishal Vaidya:
Is there a way of replacing the connector? i have torn the top of the connector......... would that be the reason that the iPhone would not start even though the ribbon is in the connector and fastened secured with the white plastic tab is down.
Make sure that the battery is charged up as the battery drains while the phone is off - i had this. And also the step 6 is very tricky while opening and while closing. make sure you have fixed all the tabs to their connectors. Also I got frustrated when my display didnt turn ON but I gave 24hours till i did anything so i cooled down-and next day I did it.
Citazione da denyem:
HOW? My device display doesn't turns on (
everything well up to when me and' jumped the white tongue of the lock connector, as can I make up for?
Use a spudger to disconnect the ribbon cable labeled "6."
If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
Altre 142 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti1Commento della guida
Hi, thank you for the instructions! Maybe you can help. I'm tryin to recover data from a logic board of an iphone 3gs. I bought a working iphone 3gs and opened it, it now has a blue logic board. After replacing the blue to the green, the phone says 'connect to itunes' and does not start properly. Why are there two different colours of logic boards, what's the difference? Thanks for helping!
