Salta al contenuto principale
iPhone 15 Pro Max Front Camera Assembly Replacement
Cosa ti serve
  1. iPhone 15 Pro Max Front Camera Assembly Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Prepare your phone for disassembly: passo 1, immagine 2 di 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPhone 15 Pro Max Front Camera Assembly Replacement, Tape over any cracks: passo 2, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPhone 15 Pro Max Front Camera Assembly Replacement, Mark your opening picks: passo 3, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Mark your opening picks: passo 3, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Mark your opening picks: passo 3, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the pentalobe screws: passo 4, immagine 1 di 1
    • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the bottom edge: passo 5, immagine 1 di 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Chiedi a FixBot
    Aggiungi Commento
  6. iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: passo 6, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: passo 6, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  7. iPhone 15 Pro Max Front Camera Assembly Replacement, Screen information: passo 7, immagine 1 di 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Chiedi a FixBot
    Aggiungi Commento
  8. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the bottom edge adhesive: passo 8, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the bottom edge adhesive: passo 8, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the bottom edge adhesive: passo 8, immagine 3 di 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
    Aggiungi Commento
  9. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the right edge: passo 9, immagine 1 di 1
    • Heat the right edge of the screen until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  10. iPhone 15 Pro Max Front Camera Assembly Replacement, Position the opening pick: passo 10, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Position the opening pick: passo 10, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Position the opening pick: passo 10, immagine 3 di 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    Chiedi a FixBot
    Aggiungi Commento
  11. iPhone 15 Pro Max Front Camera Assembly Replacement, Release the right clip: passo 11, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Release the right clip: passo 11, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Release the right clip: passo 11, immagine 3 di 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
    Chiedi a FixBot
    Aggiungi Commento
  12. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the right edge adhesive: passo 12, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the right edge adhesive: passo 12, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the right edge adhesive: passo 12, immagine 3 di 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    Chiedi a FixBot
    Aggiungi Commento
  13. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the top edge: passo 13, immagine 1 di 1
    • Heat the top edge of the screen until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  14. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the top edge adhesive: passo 14, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the top edge adhesive: passo 14, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the top edge adhesive: passo 14, immagine 3 di 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
    Chiedi a FixBot
    Aggiungi Commento
  15. iPhone 15 Pro Max Front Camera Assembly Replacement, Heat the left edge: passo 15, immagine 1 di 1
    • Heat the left edge of the screen until it's hot to the touch.
    Chiedi a FixBot
    Aggiungi Commento
  16. iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the left edge adhesive: passo 16, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the left edge adhesive: passo 16, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Separate the left edge adhesive: passo 16, immagine 3 di 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  17. iPhone 15 Pro Max Front Camera Assembly Replacement, Swing open the screen: passo 17, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Swing open the screen: passo 17, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Swing open the screen: passo 17, immagine 3 di 3
    • Gently swing open the screen to the left of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
    Chiedi a FixBot
    Aggiungi Commento
  18. iPhone 15 Pro Max Front Camera Assembly Replacement, Unfasten the logic board cover: passo 18, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Unfasten the logic board cover: passo 18, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
    • One 2.1 mm‑long screw
    • Five 1.5 mm‑long screws
    Chiedi a FixBot
    Aggiungi Commento
  19. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the logic board cover: passo 19, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the logic board cover: passo 19, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the logic board cover: passo 19, immagine 3 di 3
    • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
    • Remove the cover.
    Chiedi a FixBot
    Aggiungi Commento
  20. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the battery: passo 20, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the battery: passo 20, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the battery: passo 20, immagine 3 di 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    Chiedi a FixBot
    Aggiungi Commento
  21. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the ambient light sensor: passo 21, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the ambient light sensor: passo 21, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  22. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the screen: passo 22, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the screen: passo 22, immagine 2 di 2
    • Disconnect the screen press connector.
    Chiedi a FixBot
    Aggiungi Commento
  23. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the screen: passo 23, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the screen: passo 23, immagine 2 di 2
    • Remove the screen.
    • During reassembly, stop here and use this guide to install new screen adhesive.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    Chiedi a FixBot
    Aggiungi Commento
  24. iPhone 15 Pro Max Front Camera Assembly Replacement, Unfasten the earpiece speaker: passo 24, immagine 1 di 1
    • Use a Phillips #000 driver to remove the two screws securing the earpiece speaker:
    • One 1.8 mm screw
    • One 2.4 mm screw
    Chiedi a FixBot
    Aggiungi Commento
  25. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the earpiece speaker: passo 25, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the earpiece speaker: passo 25, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the earpiece speaker: passo 25, immagine 3 di 3
    • Insert the flat end of your spudger between the left edge of the earpiece speaker and the frame.
    • Pry up until you can grab the speaker with your fingers.
    • Remove the speaker.
    • During reassembly, insert the speaker at a downward angle so the gasket slides into its recess in the top edge of the frame.
    Chiedi a FixBot
    Aggiungi Commento
  26. iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the front camera assembly: passo 26, immagine 1 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the front camera assembly: passo 26, immagine 2 di 3 iPhone 15 Pro Max Front Camera Assembly Replacement, Disconnect the front camera assembly: passo 26, immagine 3 di 3
    • Use the tip of an opening pick to pry up and disconnect the microphone, front camera, and proximity sensor press connectors from the top of the logic board (three connectors in total).
    Chiedi a FixBot
    Aggiungi Commento
  27. iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the front camera assembly: passo 27, immagine 1 di 2 iPhone 15 Pro Max Front Camera Assembly Replacement, Remove the front camera assembly: passo 27, immagine 2 di 2
    • Use tweezers or your fingers to pull the front camera assembly out of its recess in the frame and remove it.
    • Be careful not to touch the camera or sensor lenses.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Altre 5 persone hanno completato questa guida.
Clay Eickemeyer
Membro da: 09/19/22
104.318 Reputazione
472 guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
17.854 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 24
Ultimi 7 giorni: 105
Ultimi 30 giorni: 428
Tutti i Tempi: 12,455
