Salta al contenuto principale
iPhone 11 Display Panel Replacement
Cosa ti serve
Panoramica Video
  1. iPhone 11 Display Panel Replacement, Remove the pentalobe screws: passo 1, immagine 1 di 2 iPhone 11 Display Panel Replacement, Remove the pentalobe screws: passo 1, immagine 2 di 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 11 Display Panel Replacement, Mark your opening picks: passo 2, immagine 1 di 3 iPhone 11 Display Panel Replacement, Mark your opening picks: passo 2, immagine 2 di 3 iPhone 11 Display Panel Replacement, Mark your opening picks: passo 2, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 11 Display Panel Replacement, Tape over any cracks: passo 3, immagine 1 di 3 iPhone 11 Display Panel Replacement, Tape over any cracks: passo 3, immagine 2 di 3 iPhone 11 Display Panel Replacement, Tape over any cracks: passo 3, immagine 3 di 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 11 Display Panel Replacement, Anti-Clamp instructions: passo 4, immagine 1 di 3 iPhone 11 Display Panel Replacement, Anti-Clamp instructions: passo 4, immagine 2 di 3 iPhone 11 Display Panel Replacement, Anti-Clamp instructions: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Clamp
    $24.95
    Compra
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 11 Display Panel Replacement: passo 5, immagine 1 di 3 iPhone 11 Display Panel Replacement: passo 5, immagine 2 di 3 iPhone 11 Display Panel Replacement: passo 5, immagine 3 di 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 11 Display Panel Replacement: passo 6, immagine 1 di 3 iPhone 11 Display Panel Replacement: passo 6, immagine 2 di 3 iPhone 11 Display Panel Replacement: passo 6, immagine 3 di 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 11 Display Panel Replacement, Heat the lower edge of the phone: passo 7, immagine 1 di 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
  8. iPhone 11 Display Panel Replacement: passo 8, immagine 1 di 2 iPhone 11 Display Panel Replacement: passo 8, immagine 2 di 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone 11 Display Panel Replacement, Lift the display slightly: passo 9, immagine 1 di 3 iPhone 11 Display Panel Replacement, Lift the display slightly: passo 9, immagine 2 di 3 iPhone 11 Display Panel Replacement, Lift the display slightly: passo 9, immagine 3 di 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 11 Display Panel Replacement, Separate the screen adhesive: passo 10, immagine 1 di 3 iPhone 11 Display Panel Replacement, Separate the screen adhesive: passo 10, immagine 2 di 3 iPhone 11 Display Panel Replacement, Separate the screen adhesive: passo 10, immagine 3 di 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 11 Display Panel Replacement, Screen information: passo 11, immagine 1 di 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone 11 Display Panel Replacement: passo 12, immagine 1 di 3 iPhone 11 Display Panel Replacement: passo 12, immagine 2 di 3 iPhone 11 Display Panel Replacement: passo 12, immagine 3 di 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 11 Display Panel Replacement: passo 13, immagine 1 di 3 iPhone 11 Display Panel Replacement: passo 13, immagine 2 di 3 iPhone 11 Display Panel Replacement: passo 13, immagine 3 di 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  14. iPhone 11 Display Panel Replacement: passo 14, immagine 1 di 2 iPhone 11 Display Panel Replacement: passo 14, immagine 2 di 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  15. iPhone 11 Display Panel Replacement, Remove the suction cup: passo 15, immagine 1 di 1
    • Pull the small nub on the suction cup to detach it from the front panel.
  16. iPhone 11 Display Panel Replacement, Open the iPhone: passo 16, immagine 1 di 3 iPhone 11 Display Panel Replacement, Open the iPhone: passo 16, immagine 2 di 3 iPhone 11 Display Panel Replacement, Open the iPhone: passo 16, immagine 3 di 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 11 Display Panel Replacement, Display Assembly: passo 17, immagine 1 di 2 iPhone 11 Display Panel Replacement, Display Assembly: passo 17, immagine 2 di 2
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
  18. iPhone 11 Display Panel Replacement, Unscrew the battery connector cover: passo 18, immagine 1 di 2 iPhone 11 Display Panel Replacement, Unscrew the battery connector cover: passo 18, immagine 2 di 2
    Magnetic Project Mat
    $19.95
    Compra
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 11 Display Panel Replacement, Remove the battery connector cover: passo 19, immagine 1 di 1
    • Remove the bracket.
  20. iPhone 11 Display Panel Replacement, Disconnect the battery: passo 20, immagine 1 di 2 iPhone 11 Display Panel Replacement, Disconnect the battery: passo 20, immagine 2 di 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  21. iPhone 11 Display Panel Replacement, Unscrew the logic board cover screws: passo 21, immagine 1 di 2 iPhone 11 Display Panel Replacement, Unscrew the logic board cover screws: passo 21, immagine 2 di 2
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  22. iPhone 11 Display Panel Replacement, Remove the logic board cover bracket: passo 22, immagine 1 di 1
  23. iPhone 11 Display Panel Replacement, Disconnect the display: passo 23, immagine 1 di 3 iPhone 11 Display Panel Replacement, Disconnect the display: passo 23, immagine 2 di 3 iPhone 11 Display Panel Replacement, Disconnect the display: passo 23, immagine 3 di 3
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  24. iPhone 11 Display Panel Replacement, Disconnect the front sensors: passo 24, immagine 1 di 2 iPhone 11 Display Panel Replacement, Disconnect the front sensors: passo 24, immagine 2 di 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  25. iPhone 11 Display Panel Replacement, Remove the display assembly: passo 25, immagine 1 di 1
  26. iPhone 11 Display Panel Replacement, Unscrew the front assembly: passo 26, immagine 1 di 1
    • Remove four screws securing the speaker/sensor assembly:
    • Three 1.6 mm Phillips screws
    • One 1.3 mm Y000 screw
  27. iPhone 11 Display Panel Replacement, Flip the speaker assembly over: passo 27, immagine 1 di 3 iPhone 11 Display Panel Replacement, Flip the speaker assembly over: passo 27, immagine 2 di 3 iPhone 11 Display Panel Replacement, Flip the speaker assembly over: passo 27, immagine 3 di 3
    • Use the point of a spudger to gently pry up the top edge of the speaker.
    • Flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via very thin ribbon cables. Be careful not to strain or damage the cables.
  28. iPhone 11 Display Panel Replacement, Heat up the top edge of the display: passo 28, immagine 1 di 1
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  29. iPhone 11 Display Panel Replacement, Pry up the microphone: passo 29, immagine 1 di 3 iPhone 11 Display Panel Replacement, Pry up the microphone: passo 29, immagine 2 di 3 iPhone 11 Display Panel Replacement, Pry up the microphone: passo 29, immagine 3 di 3
    • Carefully slide the edge of your opening pick underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
  30. iPhone 11 Display Panel Replacement, Remove the ambient light sensor bracket: passo 30, immagine 1 di 2 iPhone 11 Display Panel Replacement, Remove the ambient light sensor bracket: passo 30, immagine 2 di 2
    • Use tweezers to slide the small bracket straight up and off of the ambient light sensor.
  31. iPhone 11 Display Panel Replacement, Loosen the ambient light sensor: passo 31, immagine 1 di 2 iPhone 11 Display Panel Replacement, Loosen the ambient light sensor: passo 31, immagine 2 di 2
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
    • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
  32. iPhone 11 Display Panel Replacement: passo 32, immagine 1 di 3 iPhone 11 Display Panel Replacement: passo 32, immagine 2 di 3 iPhone 11 Display Panel Replacement: passo 32, immagine 3 di 3
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
  33. iPhone 11 Display Panel Replacement, Remove the speaker + front sensors: passo 33, immagine 1 di 3 iPhone 11 Display Panel Replacement, Remove the speaker + front sensors: passo 33, immagine 2 di 3 iPhone 11 Display Panel Replacement, Remove the speaker + front sensors: passo 33, immagine 3 di 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
  34. iPhone 11 Display Panel Replacement, Unscrew the LCD shield plate: passo 34, immagine 1 di 3 iPhone 11 Display Panel Replacement, Unscrew the LCD shield plate: passo 34, immagine 2 di 3 iPhone 11 Display Panel Replacement, Unscrew the LCD shield plate: passo 34, immagine 3 di 3
    • Use a Y000 driver to remove the 1.1 mm screws securing the LCD shield:
    • Three screws on the side nearest the display cables
    • Two more screws on the opposite side
    • Press your driver firmly into the screw while turning it. If needed, you can use your spudger to brace each screw from behind, in order to apply more pressure to the screws without bending the shield.
  35. iPhone 11 Display Panel Replacement: passo 35, immagine 1 di 2 iPhone 11 Display Panel Replacement: passo 35, immagine 2 di 2
    • Remove the remaining 1.1 mm Y000 screws from the top and bottom edges of the LCD shield:
    • Two screws near the camera cutouts
    • Two screws at the bottom corners
  36. iPhone 11 Display Panel Replacement, Add a little heat: passo 36, immagine 1 di 2 iPhone 11 Display Panel Replacement, Add a little heat: passo 36, immagine 2 di 2
    • Apply a little heat from an iOpener (or hair dryer / heat gun) to the back of the display, in order to soften the adhesive securing the display cables to the LCD shield.
  37. iPhone 11 Display Panel Replacement, Unstick the display cables: passo 37, immagine 1 di 2 iPhone 11 Display Panel Replacement, Unstick the display cables: passo 37, immagine 2 di 2
    • Insert an opening pick between the display cables and LCD shield.
    • Slide it toward the bottom edge of the display to begin separating the cables.
    • Stop when you reach the end of the first cable.
  38. iPhone 11 Display Panel Replacement, Separate the two cables: passo 38, immagine 1 di 3 iPhone 11 Display Panel Replacement, Separate the two cables: passo 38, immagine 2 di 3 iPhone 11 Display Panel Replacement, Separate the two cables: passo 38, immagine 3 di 3
    • Re-insert your opening pick, this time between the two cables.
    • Slide the pick to the bottom edge of the display to separate the cables from each other.
  39. iPhone 11 Display Panel Replacement: passo 39, immagine 1 di 2 iPhone 11 Display Panel Replacement: passo 39, immagine 2 di 2
    • Grab each cable near its 90° bend, and peel them apart.
  40. iPhone 11 Display Panel Replacement: passo 40, immagine 1 di 2 iPhone 11 Display Panel Replacement: passo 40, immagine 2 di 2
    • Peel the entire digitizer cable away from the LCD shield, and fold it aside.
  41. iPhone 11 Display Panel Replacement, Lift the shield plate: passo 41, immagine 1 di 2 iPhone 11 Display Panel Replacement, Lift the shield plate: passo 41, immagine 2 di 2
    • Insert an opening pick under the top edge of the LCD shield, and twist to separate it from the display.
  42. iPhone 11 Display Panel Replacement: passo 42, immagine 1 di 2 iPhone 11 Display Panel Replacement: passo 42, immagine 2 di 2
    • Grab the LCD shield by its top edge and swing it upward a few degrees.
    • Using your spudger, press gently on the lower part of the display cable, pushing it through the cutout in the LCD shield.
  43. iPhone 11 Display Panel Replacement: passo 43, immagine 1 di 3 iPhone 11 Display Panel Replacement: passo 43, immagine 2 di 3 iPhone 11 Display Panel Replacement: passo 43, immagine 3 di 3
    • Raise the top edge of the LCD shield a bit higher, and feed the rest of the display cable through the cutout in the shield.
  44. iPhone 11 Display Panel Replacement, Separate the display cable: passo 44, immagine 1 di 3 iPhone 11 Display Panel Replacement, Separate the display cable: passo 44, immagine 2 di 3 iPhone 11 Display Panel Replacement, Separate the display cable: passo 44, immagine 3 di 3
    • Raise the LCD shield up at a higher angle, until you can see the rest of the display cable stuck to the back.
    • Slide a spudger between the LCD shield and the display cable, and separate them completely.
  45. iPhone 11 Display Panel Replacement, Check the EMI fingers: passo 45, immagine 1 di 3 iPhone 11 Display Panel Replacement, Check the EMI fingers: passo 45, immagine 2 di 3 iPhone 11 Display Panel Replacement, Check the EMI fingers: passo 45, immagine 3 di 3
    • As you lift the LCD shield, note the metal prongs on the bottom edge.
    • During reassembly, make sure these prongs (a.k.a. EMI fingers) are correctly inserted into the LCD frame as shown.
  46. iPhone 11 Display Panel Replacement, Remove the shield: passo 46, immagine 1 di 1
    • Remove the LCD shield.
  47. iPhone 11 Display Panel Replacement: passo 47, immagine 1 di 1
    • Only the LCD and digitizer remains.
Conclusione
Repair didn’t go as planned? See our extensive iPhone troubleshooting library, or specifically our iPhone 11 won't turn on page. Try our basic troubleshooting tips or you can also ask our iPhone 11 Answers community for help.
Altre 172 persone hanno completato questa guida.
Jeff Suovanen
Membro da: 08/06/13
428.107 Reputazione
259 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
23 Commenti
I am a repair technician from California, and I use your company’s tools and I gotta say that I love them. Very sleek, and the powerful magnetic bits help me get the job done. I did 5 repairs yesterday and each one finished was a good feeling of satisfaction. In the future, if you guys decide to make some sort of in-depth manual for the newer iPhones, that would be great because diagrams are not only a great way for me to sharpen my own skills, but will help make training new techs a breeze.
Cheers all the way from Fresno!
anthony_brletic - Replica
Hi, I replaced the display independently, not in the Apple service, to my disappointment I found a message in the device that warned me that the part is not original, consequently the FaceID was disabled. Can you tell me about ear? Thank you
954kuki - Replica
Getting a message saying not genuine is known issue. there is no workaround yet. as far as face ID not working, you need to check for tear on the flex as you probably damaged it during transfer. If it’s broken, there is no way to fix.
iFIX smartphone -
The Important Display Message can be removed, check here: https://www.youtube.com/watch?v=bLo0_p7O...
Ricky LV -
Great repair guide. My only issues:
1. There are no instructions for removing the metal panel from the back of the old screen (nor how to reinstall it).
2. There are no instructions for removing the old, black adhesive from around the edge of the old case (nor the much needed instructions for reinstalling the new adhesive without damaging it or compromising the purpose of replacing this adhesive). This info is also missing from the adhesive replacement page for the iPhone 11.
I was able to patiently work my way through both of these issues and complete the repair on an iPhone 11. Covering these issues as additional steps of the repair guide would be very helpful for future iFixers.
Ryan R. Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 171
Ultimi 7 Giorni: 1,261
Ultimi 30 Giorni: 5,643
Tutti i Tempi: 533,515
