Salta al contenuto principale
iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement
Andrew Bookholt
Andrew Bookholt e 3 altri collaboratori
Ultimo aggiornamento il June 19, 2024
Nessuna stima
Moderato
Introduzione
Vai al passo 1
Use this guide to replace your iPad's Headphone Jack/Microphone Assembly.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement, Display Assembly: passo 1, immagine 1 di 3 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement, Display Assembly: passo 1, immagine 2 di 3 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement, Display Assembly: passo 1, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
    2) If so,will the tape take the display’s oleophobic coating with it when removed?
    Mitch Stary - Replica
    Hola necesito comprar
    Alsone Michel - Replica
    Hola, ¿no estoy seguro si te refieres a las gafas de protección o a la pantalla? Te dejo los dos enlaces aquí:
    iPad LCD Panel
    Safety Glasses
    Sandra Hiller -
  2. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 2, immagine 1 di 2 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 2, immagine 2 di 2
    • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
    • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
    • If you do happen to break some clips, you can buy replacements here.
    A clearer explanation of the orientation is needed here. The bar code is at the top left of the iPad when you are looking at the screen.
    David Hincks - Replica
  3. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 3, immagine 1 di 2 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 3, immagine 2 di 2
    • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    Tip* "ONLY WITH METAL SPUDGER* heat it with a lighter till its warm to touch, then slide it like a butter knife. it reduces chances of chipping glass.
    luckie - Replica
    I've found that by using a thicker iPad tool dents the back less(not at all if your careful) and start prying just under the volume button and working my way down works better as the metal clips are on all sider except the right side.
    richard - Replica
    It would be really helpful to point out where all the clips and tabs are, and to show a picture of them (unbroken), so you know what you're trying to release.
    Styg - Replica
  4. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 4, immagine 1 di 2 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 4, immagine 2 di 2
    • With one spudger, work your way along the right edge of the iPad.
    • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
    • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
    • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
    Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
    richard - Replica
  5. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 5, immagine 1 di 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
    By it's BOTTOM edge.
    jonathan - Replica
  6. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 6, immagine 1 di 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
    It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
  7. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 7, immagine 1 di 3 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 7, immagine 2 di 3 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 7, immagine 3 di 3
    • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
    Adding this comment in its proper place:
    After flipping up the metal retainer, pull it sideways.
    Do not pull it up vertically.
    Joe in PA
  8. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 8, immagine 1 di 1
    • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  9. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 9, immagine 1 di 2 iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 9, immagine 2 di 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
    IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
    Roger Buttermore - Replica
  10. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 10, immagine 1 di 1
    • Remove the display assembly from the rear panel assembly.
  11. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement, Headphone Jack/Microphone Assembly: passo 11, immagine 1 di 1
    • Use the edge of an iPod opening tool or your fingernail to flip up the ZIF cable retaining flap on the headphone jack socket.
    • Be sure you pry up on the cable retaining flap, not the socket itself.
  12. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 12, immagine 1 di 1
    • Carefully pull the headphone jack cable out of its socket on the logic board.
  13. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 13, immagine 1 di 1
    • Remove the two 2.8 mm T5 Torx screws securing the headphone jack to the rear case.
  14. iPad Wi-Fi Headphone Jack/Microphone Assembly Replacement: passo 14, immagine 1 di 1
    • Remove the headphone jack from the rear case.
    • Make sure you transfer the rubber sound channel from your old microphone to the new microphone.
    • Before reinstalling the screws, be sure the headphone jack is properly seated in the headphone jack hole cut into the top edge of the rear case.
Conclusione
Altre 8 persone hanno completato questa guida.
2Commenti sulla guida
I did everything it said and it's still only playing in my left ear and not the right! I can hear very very query sound in the left ear only if I take out the right earbud but nothing has changed!
seeleywes - Replica
buy blue tooth earbuds its easy
jcw_1962 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 36,756
