Salta al contenuto principale
iPad Mini Wi-Fi Logic Board Assembly Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart e 2 altri collaboratori
Ultimo aggiornamento il August 14, 2024
Nessuna stima
Difficile
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Introduzione
Vai al passo 1
Use this guide to replace the logic board.
Cosa ti serve
Strumenti
Mostra di più…
  1. iPad Mini Wi-Fi Logic Board Assembly Replacement, Logic Board Assembly: passo 1, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement, Logic Board Assembly: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 2, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 2, immagine 2 di 2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  3. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 3, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 3, immagine 2 di 2
    • Gently pry the second (upper) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  4. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 4, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  5. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 5, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 5, immagine 2 di 2
    • Gently fold the front-facing camera cable up and out of the way of the logic board.
  6. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 6, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 6, immagine 2 di 2
    • Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
  7. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 7, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 7, immagine 2 di 2
    • Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
  8. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 8, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 8, immagine 2 di 2
    • Pry the second (upper) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the headphone jack cable connector.
  9. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 9, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 9, immagine 2 di 2
    • Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
    • Gently bend the headphone jack cable back, away from the logic board.
  10. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 10, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 10, immagine 2 di 2
    • Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
  11. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 11, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 11, immagine 2 di 2
    • Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
  12. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 12, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 12, immagine 2 di 2
    • Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
  13. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 13, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 13, immagine 2 di 2
    • Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
  14. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 14, immagine 1 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 14, immagine 2 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 14, immagine 3 di 3
    • Gently peel back the wide piece of tape covering the top of the right speaker.
  15. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 15, immagine 1 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 15, immagine 2 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 15, immagine 3 di 3
    • Continue peeling the tape, and remove it from the iPad.
  16. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 16, immagine 1 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 16, immagine 2 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 16, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
  17. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 17, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 17, immagine 2 di 2
    • Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad.
    • Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
  18. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 18, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 18, immagine 2 di 2
    • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
    • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
  19. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 19, immagine 1 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 19, immagine 2 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 19, immagine 3 di 3
    • Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
  20. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 20, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 20, immagine 2 di 2
    • De-route the antenna cable from the corner of the iPad.
  21. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 21, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 21, immagine 2 di 2
    • Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
  22. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 22, immagine 1 di 1
    • Peel the cable back from the corner of the iPad.
  23. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 23, immagine 1 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 23, immagine 2 di 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 23, immagine 3 di 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  24. iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 24, immagine 1 di 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: passo 24, immagine 2 di 2
    • Pull the antenna cable from the slot behind the Lightning connector.
Conclusione
iFixit Membro di iFixit
Staff
120 Membri
20.083 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 63
