Salta al contenuto principale
iMac 2011 SSD Upgrade (IcyDock)
Arthur Shi
Arthur Shi e 2 altri collaboratori
Ultimo aggiornamento il 1 dic 2020
40 minuti - 2 ore
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Introduzione
Vai al passo 1
Follow this guide to upgrade your iMac's hard drive with an SSD. It includes steps on installing the SSD's temperature sensor so that the Mac's fans will operate at the correct speed.
Prerequisite-only guide. SSD upgrade with temperature sensor for mid 2011 iMacs.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Strumenti
Mostra di più…
  1. iMac 2011 SSD Upgrade (IcyDock), SSD (2011 IcyDock): passo 1, immagine 1 di 3 iMac 2011 SSD Upgrade (IcyDock), SSD (2011 IcyDock): passo 1, immagine 2 di 3 iMac 2011 SSD Upgrade (IcyDock), SSD (2011 IcyDock): passo 1, immagine 3 di 3
    • Only follow the next 9 steps if you are replacing your hard drive with an SSD kit.
    • Depress the enclosure's front plate latch with your finger. While holding the latch down, swing the plate out.
    • Remove the front plate.
  2. iMac 2011 SSD Upgrade (IcyDock): passo 2, immagine 1 di 3 iMac 2011 SSD Upgrade (IcyDock): passo 2, immagine 2 di 3 iMac 2011 SSD Upgrade (IcyDock): passo 2, immagine 3 di 3
    • Line up the small SATA connectors so that the narrow side of the connector on the SSD matches the narrow side on the enclosure connector.
    • Slide the drive in through the front of the enclosure until the SATA connector is fully seated.
    • The SSD's ports connect with the enclosure in only one way. If the ports are not lining up, rotate the SSD and try again.
  3. iMac 2011 SSD Upgrade (IcyDock): passo 3, immagine 1 di 1
    • You may optionally install two Philips #1 screws that came with the enclosure kit to secure the SSD in the enclosure.
  4. iMac 2011 SSD Upgrade (IcyDock): passo 4, immagine 1 di 2 iMac 2011 SSD Upgrade (IcyDock): passo 4, immagine 2 di 2
    • Plug the included sensor-enabled SATA power cable into the wide side of the enclosure's SATA connector.
    • The cable is keyed to connect in only one way. If you can't connect the cable, rotate it 180°, and try again.
  5. iMac 2011 SSD Upgrade (IcyDock): passo 5, immagine 1 di 3 iMac 2011 SSD Upgrade (IcyDock): passo 5, immagine 2 di 3 iMac 2011 SSD Upgrade (IcyDock): passo 5, immagine 3 di 3
    • Peel the backing off of the adhesive back of the small temperature sensor board.
    • Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  6. iMac 2011 SSD Upgrade (IcyDock): passo 6, immagine 1 di 1
    • Install the mounting pins from the old hard drive onto the sides of the enclosure.
    • The holes on the enclosure may not be threaded, so screwing the mounting pins into them may require extra effort. Take your time and screw them in slowly, making sure they go in straight.
  7. iMac 2011 SSD Upgrade (IcyDock): passo 7, immagine 1 di 2 iMac 2011 SSD Upgrade (IcyDock): passo 7, immagine 2 di 2
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  8. iMac 2011 SSD Upgrade (IcyDock): passo 8, immagine 1 di 2 iMac 2011 SSD Upgrade (IcyDock): passo 8, immagine 2 di 2
    • Connect the iMac's SATA power cable to the new temperature-capable SATA power cable.
    • Route the SATA cables where they will not interfere with any other components.
  9. iMac 2011 SSD Upgrade (IcyDock): passo 9, immagine 1 di 2 iMac 2011 SSD Upgrade (IcyDock): passo 9, immagine 2 di 2
    • Connect the iMac's SATA data cable to the enclosure's SATA data connector.
Conclusione
Altre 8 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Arthur Shi
Membro da: 01/03/18
300.638 Reputazione
687 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
22.454 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 55
Tutti i Tempi: 9,034
