Salta al contenuto principale
eufy Security SpaceView Monitor Antenna Replacement
Declan Andrews
Declan Andrews e 2 altri collaboratori
Ultimo aggiornamento il January 20, 2025
35 minuti - 1 ora
Facile
Testo Confuso
Inconveniente Markup
Necessarie Più Immagini
Introduzione
Vai al passo 1
This comprehensive guide is designed to assist you in replacing the antenna on your Eufy Security SpaceView Monitor. Whether you've encountered signal issues or simply wish to enhance the device's performance, this step-by-step tutorial will guide you through the process with detailed instructions and visual aids.
Cosa ti serve
Strumenti
Mostra di più…
  1. eufy Security SpaceView Monitor Antenna Replacement, Display Assembly: passo 1, immagine 1 di 2 eufy Security SpaceView Monitor Antenna Replacement, Display Assembly: passo 1, immagine 2 di 2
    • Use an opening tool to press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Antenna Replacement, Lift the display: passo 2, immagine 1 di 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Antenna Replacement, Screen: passo 3, immagine 1 di 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Antenna Replacement: passo 4, immagine 1 di 2 eufy Security SpaceView Monitor Antenna Replacement: passo 4, immagine 2 di 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Antenna Replacement: passo 5, immagine 1 di 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
  6. eufy Security SpaceView Monitor Antenna Replacement, Motherboard: passo 6, immagine 1 di 2 eufy Security SpaceView Monitor Antenna Replacement, Motherboard: passo 6, immagine 2 di 2
    • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
  7. eufy Security SpaceView Monitor Antenna Replacement: passo 7, immagine 1 di 3 eufy Security SpaceView Monitor Antenna Replacement: passo 7, immagine 2 di 3 eufy Security SpaceView Monitor Antenna Replacement: passo 7, immagine 3 di 3
    • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
    • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
    • Lift the motherboard and disconnect the antenna connector from its port.
    • The motherboard is free from the housing and can be replaced.
  8. eufy Security SpaceView Monitor Antenna Replacement, Antenna: passo 8, immagine 1 di 1
    • Using the #00 Phillips head, unscrew the two screws fastening the antenna wire at the top right hand side.
  9. eufy Security SpaceView Monitor Antenna Replacement: passo 9, immagine 1 di 1
    • Pinch the tongs that are connecting the antenna to the fastener.
    • Pull the fastener off off the tongs.
  10. eufy Security SpaceView Monitor Antenna Replacement: passo 10, immagine 1 di 1
    • Turn the device around and pull the antenna from its connection point.
Conclusione
Declan Andrews
Membro da: 10/31/23
181 Reputazione
2 Guide realizzate
1Commento della guida
Where can I get a replacement part for the antenna?
Vincenz Marschall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 41
Tutti i Tempi: 908
