Salta al contenuto principale
ZTE ZMax Pro Power Button Replacement
Nicholas Leacox
Nicholas Leacox e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
3 - 6 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to replace the power button on your device. You will need a plastic opening tool, tweezers, and a Phillips #00 screwdriver.
Cosa ti serve
Strumenti
Mostra di più…
  1. ZTE ZMax Pro Power Button Replacement, Back Panel Assembly: passo 1, immagine 1 di 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Power Button Replacement: passo 2, immagine 1 di 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Power Button Replacement: passo 3, immagine 1 di 2 ZTE ZMax Pro Power Button Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Power Button Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Power Button Replacement: passo 5, immagine 1 di 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Power Button Replacement: passo 6, immagine 1 di 2 ZTE ZMax Pro Power Button Replacement: passo 6, immagine 2 di 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Power Button Replacement: passo 7, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Power Button Replacement: passo 8, immagine 1 di 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Power Button Replacement, Power Button: passo 9, immagine 1 di 1
    • Use the plastic opening tool to remove the lower left connector on the motherboard.
  10. ZTE ZMax Pro Power Button Replacement: passo 10, immagine 1 di 1
    • Use tweezers to pull back on the power button.
  11. ZTE ZMax Pro Power Button Replacement: passo 11, immagine 1 di 1
    • Use the tweezers to pull back on the volume buttons.
  12. ZTE ZMax Pro Power Button Replacement: passo 12, immagine 1 di 1
    • Use the tweezers to pull back on the cable connecting the power and volume button until it is removed.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S17-G3, Livingston Spring 2018 Membro di Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Membri
16 Guide realizzate
1Commento della guida
Hpw much to repair ()
Manny Carreon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,007
