Salta al contenuto principale
ZTE Boost MAX N9520 Battery Replacement
Sebastian Edinger
Sebastian Edinger e 3 altri collaboratori
Ultimo aggiornamento il August 6, 2024
Nessuna stima
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
If your battery isn't working. (on this phone it was bloated and about to burst) here is how to fix it! You will need to remove the back plate and disconnect the old battery to replace it.
Cosa ti serve
Strumenti
  1. ZTE Boost MAX N9520 Battery Replacement, Battery: passo 1, immagine 1 di 2 ZTE Boost MAX N9520 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • First, remove the microSD tray, use a sim ejector tool for this.
    • Begin by removing the upper and lower plastic panels. Pry the top with a spudger from the corners as shown in the red circle.
    • Remove the SIM card.
    • Next pry off the lower plastic panel. This one is stuck on a little bit more.
Conclusione
Altre 5 persone hanno completato questa guida.
Un commento
An additional more comprehensive wiki troubleshooting guide for the ZTE Max …compiled by a team of students here on “IFIXIT” that I recently discovered that you may also find helpful.
ZTE Max XL Troubleshooting
Jason Thompson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,136
