ZTE Blade X Max Front Camera Replacement
Introduzione
Vai al passo 1If the front camera of your ZTE Blade X Max is not functioning—blurry image, scratched lens—and you have already been through our troubleshooting guide, you will have to replace it.
This guide requires removing the back of the phone. You will have to use heating products to complete this guide. If you are using the iFixit iOpener, or a heating pad, be sure to follow the instructions for that particular product.
Cosa ti serve
Strumenti
Mostra di più…
Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Once the motherboard is exposed, locate the front camera connection in the top right corner of the motherboard.
Use the tweezers to remove the front camera.
