Salta al contenuto principale
Xiaomi Redmi Note 6 Pro Battery Replacement
Cosa ti serve
  1. Xiaomi Redmi Note 6 Pro Battery Replacement, Eject the SIM tray: passo 1, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Eject the SIM tray: passo 1, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Eject the SIM tray: passo 1, immagine 3 di 3
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Xiaomi Redmi Note 6 Pro Battery Replacement, Insert an opening pick: passo 2, immagine 1 di 2 Xiaomi Redmi Note 6 Pro Battery Replacement, Insert an opening pick: passo 2, immagine 2 di 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick between the screen and the back cover on the left edge of the phone where the SIM card tray was located.
  3. Xiaomi Redmi Note 6 Pro Battery Replacement, Release the plastic clips: passo 3, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the plastic clips: passo 3, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the plastic clips: passo 3, immagine 3 di 3
    • Slide the opening pick along the left edge to the bottom left corner to release the plastic clips.
  4. Xiaomi Redmi Note 6 Pro Battery Replacement: passo 4, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement: passo 4, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement: passo 4, immagine 3 di 3
    • Slide the opening pick along the bottom edge to the bottom right corner to release the plastic clips.
  5. Xiaomi Redmi Note 6 Pro Battery Replacement: passo 5, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement: passo 5, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement: passo 5, immagine 3 di 3
    • Slide the opening pick along the right edge of your phone to the top right corner to release the plastic clips.
  6. Xiaomi Redmi Note 6 Pro Battery Replacement, Release the remaining plastic clips: passo 6, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the remaining plastic clips: passo 6, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the remaining plastic clips: passo 6, immagine 3 di 3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to remove the back cover all the way yet! It's still connected to the motherboard!
  7. Xiaomi Redmi Note 6 Pro Battery Replacement, Swing open the phone assembly: passo 7, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Swing open the phone assembly: passo 7, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Swing open the phone assembly: passo 7, immagine 3 di 3
    • Carefully fold the phone assembly to the left side of the back cover like you'd open a book.
  8. Xiaomi Redmi Note 6 Pro Battery Replacement, Unscrew the fingerprint cable connector cover: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw securing the fingerprint cable connector cover.
  9. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the metal cover: passo 9, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the metal cover: passo 9, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the metal cover: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of blunt nose tweezers to remove the metal cover.
  10. Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the fingerprint sensor: passo 10, immagine 1 di 2 Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the fingerprint sensor: passo 10, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the fingerprint sensor cable.
  11. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the back cover: passo 11, immagine 1 di 1
    • Remove the back cover.
  12. Xiaomi Redmi Note 6 Pro Battery Replacement, Unscrew the battery connector cover: passo 12, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 3.0 mm-long screws securing the battery connector cover.
  13. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery connector cover: passo 13, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery connector cover: passo 13, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery connector cover: passo 13, immagine 3 di 3
    Compra
    • Use a pair of blunt nose tweezers to remove the battery connector cover.
  14. Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the battery: passo 14, immagine 1 di 2 Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the battery: passo 14, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the stretch-release adhesive: passo 15, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the stretch-release adhesive: passo 15, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the stretch-release adhesive: passo 15, immagine 3 di 3
    Compra
    • The battery is secured to the rear case with two pieces of stretch-release adhesive.
    • Use a pair of tweezers or a clean fingernail to peel down both battery adhesive pull-tabs to un-stick them from the bottom edge of the battery.
    • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  16. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the pull-tabs: passo 16, immagine 1 di 2 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the pull-tabs: passo 16, immagine 2 di 2
    • Grab the first pull-tab with a pair of tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery. Hold the Redmi firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  17. Xiaomi Redmi Note 6 Pro Battery Replacement: passo 17, immagine 1 di 2 Xiaomi Redmi Note 6 Pro Battery Replacement: passo 17, immagine 2 di 2
    • Repeat the previous pull-tab removal procedure on the second pull-tab.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  18. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery: passo 18, immagine 1 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery: passo 18, immagine 2 di 3 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery: passo 18, immagine 3 di 3
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Before installing a new battery remove any remaining adhesive, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Altre 3 persone hanno completato questa guida.
Adriana Zwink
Membro da: 12/18/19
50.416 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 258
Tutti i Tempi: 6,826
