Salta al contenuto principale
Xiaomi Mi 10 Lite Battery Replacement
Cosa ti serve
  1. Xiaomi Mi 10 Lite Battery Replacement, Heat the rear glass: passo 1, immagine 1 di 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Mi 10 Lite Battery Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Xiaomi Mi 10 Lite Battery Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Xiaomi Mi 10 Lite Battery Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Xiaomi Mi 10 Lite Battery Replacement, Slice the adhesive: passo 3, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Slice the adhesive: passo 3, immagine 2 di 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 10 Lite Battery Replacement, Slice the adhesive: passo 4, immagine 1 di 3 Xiaomi Mi 10 Lite Battery Replacement, Slice the adhesive: passo 4, immagine 2 di 3 Xiaomi Mi 10 Lite Battery Replacement, Slice the adhesive: passo 4, immagine 3 di 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 10 Lite Battery Replacement: passo 5, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement: passo 5, immagine 2 di 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Mi 10 Lite Battery Replacement: passo 6, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement: passo 6, immagine 2 di 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  7. Xiaomi Mi 10 Lite Battery Replacement, Remove the rear glass: passo 7, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Remove the rear glass: passo 7, immagine 2 di 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Xiaomi Mi 10 Lite Battery Replacement, Unfasten the motherboard cover screws: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the ten 3.9 mm-long screws securing the motherboard cover.
  9. Xiaomi Mi 10 Lite Battery Replacement, Pry up the motherboard cover: passo 9, immagine 1 di 3 Xiaomi Mi 10 Lite Battery Replacement, Pry up the motherboard cover: passo 9, immagine 2 di 3 Xiaomi Mi 10 Lite Battery Replacement, Pry up the motherboard cover: passo 9, immagine 3 di 3
    • Insert the tip of an opening pick underneath the right edge of the motherboard cover.
    • Slide the opening pick to the top right corner of the motherboard cover to unhinge the plastic clips and pry it up.
  10. Xiaomi Mi 10 Lite Battery Replacement, Remove the motherboard cover: passo 10, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Remove the motherboard cover: passo 10, immagine 2 di 2
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  11. Xiaomi Mi 10 Lite Battery Replacement, Disconnect the battery cable: passo 11, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Disconnect the battery cable: passo 11, immagine 2 di 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  12. Xiaomi Mi 10 Lite Battery Replacement, Disconnect the interconnect cable: passo 12, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Disconnect the interconnect cable: passo 12, immagine 2 di 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  13. Xiaomi Mi 10 Lite Battery Replacement, Free the battery: passo 13, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Free the battery: passo 13, immagine 2 di 2
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Fold the interconnect flex cable towards the charging port in order to get free access to both battery pull tabs.
    • You might want to use a small piece of tape to temporarily stick the cable onto your working surface to avoid accidentally damaging it during the battery removal.
  14. Xiaomi Mi 10 Lite Battery Replacement, Peel off the battery pull-tabs: passo 14, immagine 1 di 3 Xiaomi Mi 10 Lite Battery Replacement, Peel off the battery pull-tabs: passo 14, immagine 2 di 3 Xiaomi Mi 10 Lite Battery Replacement, Peel off the battery pull-tabs: passo 14, immagine 3 di 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labeled with an A off the battery.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labeled with a B off the battery.
  15. Xiaomi Mi 10 Lite Battery Replacement, Remove the battery: passo 15, immagine 1 di 3 Xiaomi Mi 10 Lite Battery Replacement, Remove the battery: passo 15, immagine 2 di 3 Xiaomi Mi 10 Lite Battery Replacement, Remove the battery: passo 15, immagine 3 di 3
    • Grab both pull–tab ends labeled with an A and pull up on the orange adhesive strip to lift the battery out of its recess and swing it up to an upright position.
    • Although these adhesive tabs are supposed to make the battery removal easier, they may require some force. In case you're having trouble removing the battery, you can apply a heated iOpener to the center of the display to loosen the adhesive underneath.
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
  16. Xiaomi Mi 10 Lite Battery Replacement, Remove the battery adhesive: passo 16, immagine 1 di 2 Xiaomi Mi 10 Lite Battery Replacement, Remove the battery adhesive: passo 16, immagine 2 di 2
    • In case you're replacing the adhesive sticker with a new one, peel the battery's adhesive sticker off the midframe and clean the relevant areas with isopropyl alcohol (>90%). Let the alcohol dry before installing new adhesive.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 6 persone hanno completato questa guida.
Dominik Schnabelrauch
Membro da: 11/23/16
203.632 Reputazione
682 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.153 Guide realizzate
Un commento
Seguí los pasos de esta guía pero creo que aunque este punto es válido:
(Y de hecho el procesador también puede ser dañado si se superan los 100-105º en T-Junction)
Es mucho más probable que ocurra lo contrario: que rompas el cristal templado trasero intentando despegarlo sino has aplicado suficiente calor. Mi recomendación es que tiren muy muy suavemente y sigan calentando hasta que se despegue sin esfuerzo. También que compren una tapa trasera de repuesto por si acaso ya que reinstalar una tapa resquebrajada no es en absoluto recomendable y dejarlo sin tapa, aún menos.
También mencionar que hay que tener especial cuidado con el cable azul que va de arriba a abajo ya que es susceptible de estirarse/romperse al tirar si se queda pegado al adhesivo o que lo rompas involuntariamente al pasar la pua.
Dom - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 103
Ultimi 30 Giorni: 474
Tutti i Tempi: 7,770
