Sostituzione Disc Drive Xbox
Introduzione
Vai al passo 1Consulta questa guida per cambiare il disk drive in una Xbox Microsoft.
Cosa ti serve
Utilizza uno strumento spudger di metallo per rimuoverli.
The screw is in the outside corner. If you pry up only the half of the foot on that side, you can easily remove the (very long) screw, and the foot will stay attached.
Ah I always used to damage the feet.
Puoi rimuovere direttamente le etichette o trovare le fessure delle viti al tatto e semplicemente bucare le etichette.
It is also easy to feel for the screw hole with your finger and then cut a hole, or punch it out with the tip of the Torx driver to reveal the screw.
Rimuovi il cavo a nastro e il cavo di alimentazione dallo stesso hard drive.
Remember that the new drive will only work if it has been properly prepared, and the Xbox has been modified.
there is NO way to legally replace the xbox hard drive. it is LOCKED to the motherboard and the xbox will not boot to the OS or make it past the BIOS if the HDD is not the one that came with it from the factory. you MUST use a mod chip and “home brew” to do a HDD swap and expect it to work
Could you point me to a good tutorial on using a modding an original Xbox? All I want to do is swap an HDD in original Xbox with another original Xbox HDD because I want my saved game data. Any way to figure this out? Seems like modding is a !&&* of a burden.
Can i replace the original hard drive with new one
Rimuovi il disk drive, dovresti riuscire senza alcuna fatica.
Stacca il cavo a nastro e i cavi gialli dal lato posteriore del disk drive.
Premi sulle linguette di plastica nere (che trovi ai lati del drive) per rimuoverlo dalla sua custodia. Una volta rimosso, tieni il disk drive da parte.
It is ok to remove the drive if it isn't dead. If repairs are required to the drive it needs to be removed from the drive's housing.
Surely this needs to be removed to access the motherboard?
Yes, it does.
Zerobuss -
Per rimontare il dispositivo, segui le istruzioni nell'ordine inverso.
Altre 66 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
8Commenti sulla guida
http://www.ebay.com/gds/How-To-Determine...
Utilize the information on this website to determine what Xbox version you have so you know what replacement parts to look for.
The final comment mentions “only remove if dead.” What about a disc drive that closes and opens immediately….in other words, won’t stay closed. Is this a sign of a defective disc drive too?
I am having the same issue, Miguel.
Did you buy a new drive or figure out a better fix?
Thanks
Ben C. -
I learned that you need to change out the drive belt in the disc drive. Over time it wears out and either won't open, stays open, or will open/close continuously. I changed my drive belt and it started working fine.
Can anyone help..My Xbox can't read games..I took it apart and cleaned it, still can't read games
if your having the same problems as me this laser inside could be done for and need a replacement. you could also figure out how to use a multi-meter and read the ohms to see if the laser is getting enough power. but i don't know how todo that and nothing on youtube help. there are so many different drive and most people choose the easier drives/better drives to repair. I would suggest finding what drive you have then after that looking up the drives model and see is there's anything about replacing or adjusting the laser. another solution is you can either buy a whole new xbox that isn't working and take the drive out and see if that works but it or you could just buy a new drive of ebay or any site that may have it. a nice thing about the og xbox is that that disc drive and the motherboard aren't married so you don't need to take that key out and match it with the motherboard.
I have the Xbox original..
I’m having the same problems too ??♂️
