Salta al contenuto principale
Xbox 360 E RF Module Replacement
Sarah
Sarah e 4 altri collaboratori
Ultimo aggiornamento il 11 mar 2023
5 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the RF module in your Xbox 360 E.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  1. Xbox 360 E RF Module Replacement, Top Panel: passo 1, immagine 1 di 1
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Xbox 360 E RF Module Replacement: passo 2, immagine 1 di 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Xbox 360 E RF Module Replacement: passo 3, immagine 1 di 3 Xbox 360 E RF Module Replacement: passo 3, immagine 2 di 3 Xbox 360 E RF Module Replacement: passo 3, immagine 3 di 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Xbox 360 E RF Module Replacement, Bottom Panel: passo 4, immagine 1 di 1
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  5. Xbox 360 E RF Module Replacement: passo 5, immagine 1 di 2 Xbox 360 E RF Module Replacement: passo 5, immagine 2 di 2
    • Slide the spudger along the crevice to separate the grated face and the top body.
  6. Xbox 360 E RF Module Replacement: passo 6, immagine 1 di 3 Xbox 360 E RF Module Replacement: passo 6, immagine 2 di 3 Xbox 360 E RF Module Replacement: passo 6, immagine 3 di 3
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  7. Xbox 360 E RF Module Replacement, Front Panel: passo 7, immagine 1 di 3 Xbox 360 E RF Module Replacement, Front Panel: passo 7, immagine 2 di 3 Xbox 360 E RF Module Replacement, Front Panel: passo 7, immagine 3 di 3
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    Doesn’t work for me either
    Mason Hayes - Replica
    Yeah.... If possible, better to just turn the machine on. Open the tray, unplug the console. Then lift it off. Closer the tray afterwards.
    Christopher Mee - Replica
    Better go from behind... This way inside is hard as hell and wondering if you break something... :-(
    Petr Sourek - Replica
  8. Xbox 360 E RF Module Replacement: passo 8, immagine 1 di 3 Xbox 360 E RF Module Replacement: passo 8, immagine 2 di 3 Xbox 360 E RF Module Replacement: passo 8, immagine 3 di 3
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  9. Xbox 360 E RF Module Replacement: passo 9, immagine 1 di 3 Xbox 360 E RF Module Replacement: passo 9, immagine 2 di 3 Xbox 360 E RF Module Replacement: passo 9, immagine 3 di 3
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    My actual disk tray came off the track looking into the best way to repair it
    David Mitchell - Replica
  10. Xbox 360 E RF Module Replacement: passo 10, immagine 1 di 3 Xbox 360 E RF Module Replacement: passo 10, immagine 2 di 3 Xbox 360 E RF Module Replacement: passo 10, immagine 3 di 3
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  11. Xbox 360 E RF Module Replacement: passo 11, immagine 1 di 2 Xbox 360 E RF Module Replacement: passo 11, immagine 2 di 2
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  12. Xbox 360 E RF Module Replacement: passo 12, immagine 1 di 3 Xbox 360 E RF Module Replacement: passo 12, immagine 2 di 3 Xbox 360 E RF Module Replacement: passo 12, immagine 3 di 3
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
  13. Xbox 360 E RF Module Replacement, RF Module: passo 13, immagine 1 di 3 Xbox 360 E RF Module Replacement, RF Module: passo 13, immagine 2 di 3 Xbox 360 E RF Module Replacement, RF Module: passo 13, immagine 3 di 3
    • Looking at the body of the device, locate the green panel to the right of the CD drive.
    • Remove the two 6 mm screws located on the top left and middle right with a T8 Torx screwdriver.
    • Grip the middle of the green board and gently pull it out.
Conclusione
Altre 6 persone hanno completato questa guida.
Sarah
Membro da: 01/30/14
1.822 Reputazione
4 Guide realizzate
Cal Poly, Team 2-11, Amido Winter 2014 Membro di Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Membri
44 Guide realizzate
2Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 66
Tutti i Tempi: 4,548
