Salta al contenuto principale
WowWee MiP Robot Battery Replacement
Moira Keahon
Moira Keahon e 9 altri collaboratori
Ultimo aggiornamento il December 19, 2023
5 minuti
Facile
Introduzione
Vai al passo 1
The WowWee MiP robot has a tendency towards short battery life. If the MiP seems too slow or stops responding, use this guide to change the MiP’s batteries. The MiP’s batteries are located in a battery pack on the robot's back.
  1. WowWee MiP Robot Battery Replacement, Battery: passo 1, immagine 1 di 2 WowWee MiP Robot Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Battery Replacement: passo 2, immagine 1 di 2 WowWee MiP Robot Battery Replacement: passo 2, immagine 2 di 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
Conclusione
Altre 3 persone hanno completato questa guida.
14Commenti sulla guida
Its a programmer MIP not this kind.
Azariah Trumble - Replica
Same question here, instructions needed for CODER MIP as it doesn't seem to be a holding a charge.
Gil Acosta - Replica
does spare battery adapter vailable(not reachargeable)
coolboyz' channel - Replica
Coder Mip Battery says fully charged - but Coder Mip doesnt turn on?
Sadie - Replica
Coder MiP one day old - was working - battery says fully charged - but Coder MiP doesn’t turn on? Any suggestions?
Sadie - Replica
Brand new Coder MIP - fully charged (approx. 20 hours charging time) after 5-7 minutes in use, it run out of battery already. Is this normal?
Barbe _74 - Replica
Brand new Coder MiP (fully charged for approx. 20 hours) runs out of battery after only 5-7 minutes in use. Is this normal?
Barbe _74 - Replica
Same CODER MIP here - we got erratic performance from the battery pack. A smart slap seems required to ensure a tight battery connection after a robot fall, otherwise it appears to have run out of battery. Not optimal, but it allowed us to play for a while.
dagmarfraser - Replica
My Mip doesn’t work even if I replace the batteries. It acts very strange. It keeps making a clicking noise
Daniel Cleiland - Replica
Mine does to
Clarrie O'HARE -
I have A Coder MiP instead of a plain MiP
Are there different instructions.
Clarrie O'HARE - Replica
my mip is not working because l charged it for about a long time and l tryed to get the app but dident work any suggestions?
sappy - Replica
MIP is just not kind and l cant believe that its not working
sappy - Replica
its also very dirty
sappy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 12,802
