Salta al contenuto principale
WowWee CHiP Robot Dog Wheel Replacement
Joseph Dantes
Joseph Dantes e 3 altri collaboratori
Ultimo aggiornamento il February 25, 2024
4 minuti
Molto facile
Introduzione Migliore
Cosa ti serve
Strumenti
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: passo 1, immagine 1 di 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: passo 2, immagine 1 di 2 WowWee CHiP Robot Dog Wheel Replacement: passo 2, immagine 2 di 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
    Cant get the eyes to lite up, suggestions?
    Daniel peters - Replica
  3. WowWee CHiP Robot Dog Wheel Replacement: passo 3, immagine 1 di 2 WowWee CHiP Robot Dog Wheel Replacement: passo 3, immagine 2 di 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
    what is the purpose for removing the battery if you cannot buy a new one?
    v scigliano - Replica
    I need a new batties in my chip dog. Please tell me we're can u get it from and bed stand
    janie alexander - Replica
  4. WowWee CHiP Robot Dog Wheel Replacement: passo 4, immagine 1 di 3 WowWee CHiP Robot Dog Wheel Replacement: passo 4, immagine 2 di 3 WowWee CHiP Robot Dog Wheel Replacement: passo 4, immagine 3 di 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
    where i find this battery
    Abodi Jml - Replica
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: passo 5, immagine 1 di 1
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: passo 6, immagine 1 di 1
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: passo 7, immagine 1 di 1
    • Pull and remove wheel.
    можно не отключать.а в каком положении должны быть инкодеры при таком положении лап? при замене шестеренок, как правильно выставить нулевое значение инкодера?
    Aleksey - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
3Commenti sulla guida
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Replica
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Replica
Heads up it is really hard to turn
Mary Pownsu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 49
Tutti i Tempi: 4,286
