Salta al contenuto principale
Vornado Zippi Fan Thermal cutout Replacement
Albert Straub
Albert Straub e 3 altri collaboratori
Ultimo aggiornamento il June 26, 2024
Nessuna stima
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
My Zippi fan stopped working after it fell over and its blades were held so that they could not rotate. The fan thus overheated and caused the thermal cutout to fail. This series shows how I opened the fan and replaced the thermal cutout.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Vornado Zippi Fan Thermal cutout Replacement, Locate and remove side screws: passo 1, immagine 1 di 1
    • There are two obvious screws on the sides of the fan. These are of the "Phillips" variety and need to be removed.
    • Remove the wire base by simply pulling each side out of the plastic housing. They are only held in place by the springiness of the wire base.
  2. Vornado Zippi Fan Thermal cutout Replacement, Remove the hidden screw in the base: passo 2, immagine 1 di 1
    • All of the screws are of the "Phillips" variety. It takes a bit of fiddling to get the screwdriver blade to engage with the screw but then it backs right out. Just leave the screw behind the rubber bit as it would be a nightmare to get it out and we will need it there for reassembly anyway.
  3. Vornado Zippi Fan Thermal cutout Replacement, Carefully pry off the power knob and the front propeller: passo 3, immagine 1 di 1
    • Be careful not to ding up the plastics. I had to use quite a bit of force to get the propeller off.
    To help here, I took a piece of wire and got it under the cap and pulled from two sides. The propeller popped up pretty quick
    Sheridan Comer - Replica
  4. Vornado Zippi Fan Thermal cutout Replacement, Remove the remaining 4 screws holding the case together: passo 4, immagine 1 di 1
    • After pulling away both sides of the plastic case, remove the black plastic housing by removing the two screws that hold it in place.
  5. Vornado Zippi Fan Thermal cutout Replacement, Cut away the insulation around the thermal cutout: passo 5, immagine 1 di 1
    • Use a razor knife and carefully cut away the silicon insulation around the thermal cutout.
    • Note that the cutout is a 115 degree C 2 amp device. I replaced it with a Panasonic EYP-2BN110 which is available from DataAlchemy on Amazon Marketplace.
    • Clip the old unit out and melt a blob of solder on the wires that stick out. Then clip short the leads of the new thermal cutout so that they just reach the exposed wires.
    • Hold the thermal cutout as far away from the device as possible with needle-nose pliers as a heatsink so that the soldering iron doesn't blow the fuse and quickly solder the fuse in place.
    • Now thread a bit of electrical insulation around the cutout to cover the exposed wires. Do not use more than a layer or the cutout may not operate when it is needed.
    My Zippi suffered the EXACT same fate as this one. I was able to get it disassembled, no problem. But now that I am looking at the bare motor assembly, I have not cut away the “silicon insulation” because I cannot determine exactly what that is from the photos. My motor looks a bit different than this one, and I also cannot determine where the Fuse is, or if there even *is* one at all. There does not appear to be a Thermal Fuse or anything resembling that anywhere on the motor that I can see without destructively going any further into it. One side of the motor looks slightly different from the other side. There does appear to be something lying just underneath a rubbery sort of tape, but it doesn’t look like any type of fuse I have ever seen. It runs the entire width of the windings, and I cannot see any wire leads connecting to it at all. There is a tiny fuse in the wall plug housing which I have checked to be OK. A little bit of help here would sure be nice. Thanks. Gary
    Gary DeLoach - Replica
    Hi, I have exactly the same - the silicon insulation appears to have been changed for plastic (hard at that) and there is no sign of the fuse shown in the picture above - the only wires visible are tucked to the side and go into the centre of the motor - no fuse visible. Again nothing further but destructively going into the motor and coil itself. It's as if vornado read this and then changed the design to make it more difficult for people to simply fix !! Any chance of an update ? What's odd is that the comment above is from 2018 - my fans were purchased in 2014 so well before this comment.
    gerrykavanagh - Replica
  6. Vornado Zippi Fan Thermal cutout Replacement, Reassemble in the reverse order: passo 6, immagine 1 di 1
    • Now simply put all of the pieces back together in the reverse order that you took them apart. Here is my Zippi, good as new and ready for the hot summer.
Conclusione
Altre 4 persone hanno completato questa guida.
Albert Straub
Membro da: 05/06/13
269 Reputazione
1 Guida realizzata
4 Commenti
Thank you, my thermal was fine but my zippi was making an annoying clicking sound - just the disassembly, lubrication of the motor shaft with PTFE and putting it back together fixed it and it's running at a nice white noise hum right now better than ever.
Jonathan Bell - Replica
Thank you very much! I thought the motor had burnt out!
Idmi - Replica
Thanks for the instructions on removal. My Zippi's shaft is making a lot of noise--seems like a bearing problem. Don't know how to fix.
Chien-sheng Tsai - Replica
My Zippi fell off my nightstand and started making noise. This may not help everyone but I simply tightened the screws in the body to pull the sides in tighter and the sound went away. Do not overtighten as the screws may strip.
Albert Straub - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 3,742
