VooDooQuad 250 Propeller Replacement
Introduzione
Vai al passo 1Chipping or breaking of a propeller for any level drone flier is inevitable. It is an incredibly common troubleshoot, but luckily a simple replacement. Make sure you have a clean working station, and all you'll need is a set of pliers to put on the new set.
Cosa ti serve
Be careful removing the bolts multiple times because it may create slippage and then this will not allow the bolt nor the propeller to stay on. To reassemble your device, follow these instructions in reverse order
