Salta al contenuto principale
Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement
tate campbell
tate campbell e 2 altri collaboratori
Ultimo aggiornamento il 10 dic 2018
5 - 15 minuti
Moderato
Introduzione
Vai al passo 1
If the battery appears to be working, and the device charges normally when sitting on the charging stand, but does not charge when connected to a USB cable, you may need to replace the Micro-USB Port. Here we have included a step-by-step guide for the replacement of the Port.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
Mostra di più…
  1. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement, Micro-USB Port: passo 1, immagine 1 di 1
  2. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 2, immagine 1 di 2 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the nylon spudger under the black flap, and pull upwards toward yourself to disconnect it.
    • Be careful, as the flap can easily break off.
  3. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, immagine 1 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, immagine 2 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 3, immagine 3 di 3
    • Using the T-5 bit, unscrew the three 5mm screws, two attached to the green board, one attached to the black board.
  4. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, immagine 1 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, immagine 2 di 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: passo 4, immagine 3 di 3
    • Using the nylon spudger, remove the silver cylindrical component followed by the green then black components
    • Be careful not to break the wires that are holding the three components together.
Conclusione
1Commento della guida
Is there a way to purchase a replacement battery?
Gasman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 421
