Salta al contenuto principale
Violin Strings Replacement
Brittany Preston
Brittany Preston e 2 altri collaboratori
Ultimo aggiornamento il March 4, 2020
10 minuti
Molto facile
Introduzione
Vai al passo 1
This guide is intended to help users through the process of fixing broken or worn out violin strings. A violin has four strings: E, A, D, & G. The order of the strings from left to right is G, D, A, & E. The G string is the deepest pitched string and the E is the highest pitched string. The purpose of this guide is to enable violin players to restring their violin on their own instead of having it done at a music store.
  1. Violin Strings Replacement, Strings: passo 1, immagine 1 di 2 Violin Strings Replacement, Strings: passo 1, immagine 2 di 2
    • Turn the peg belonging to the string you are wanting to change to loosen the string.
    • Violins have four string. The strings from left to right go: G, D, A, & E.
  2. Violin Strings Replacement: passo 2, immagine 1 di 1
    • Pull the string out of the peg.
  3. Violin Strings Replacement: passo 3, immagine 1 di 2 Violin Strings Replacement: passo 3, immagine 2 di 2
    • Remove the opposite end of the string from the fine tuner holder.
  4. Violin Strings Replacement: passo 4, immagine 1 di 2 Violin Strings Replacement: passo 4, immagine 2 di 2
    • Place new string in peg hole.
  5. Violin Strings Replacement: passo 5, immagine 1 di 1
    • Turn the peg to tighten the string.
  6. Violin Strings Replacement: passo 6, immagine 1 di 2 Violin Strings Replacement: passo 6, immagine 2 di 2
    • Place nub in fine tuner holder.
  7. Violin Strings Replacement: passo 7, immagine 1 di 1
    • Make sure the string is sitting in the groove in the bridge.
  8. Violin Strings Replacement: passo 8, immagine 1 di 1
    • Gently tug on string to make sure it is secure.
Conclusione
Altre 5 persone hanno completato questa guida.
1Commento della guida
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
Svasangana jeevi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 33
Tutti i Tempi: 15,482
