Verizon Ellipsis Jetpack MHS800L Battery Replacement
Introduzione
Vai al passo 1What you can expect from this guide is a step by step process on how to remove the battery on a Verizon Ellipsis Jetpack MHS800L.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
Remove three 1.25 mm screws.
Are steps 3 and 4 reversed? Where are the 3 screws?
Th3 first left corner has a screw but under the cover on the others is just a black circle
Yes steps 3 and 4 are reversed. After removing the single screen (Philips #000 works better than #00), flip the device over and follow step 4 to remove the top black cover. Then follow step 3 to remove the 3 screw shown.
Attrezzo utilizzato in questo passaggio:iFixit Opening Picks (Set of 6)$4.99
Use a plastic pick at the seams and pry open the case.
Once you have the case off of your device gently pull your battery away from the device.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
oh, good
‘only squeeze hard enough’
it’s a good thing I have a bucket of these upon which to experiment? oh, wait, I don’t.
I just replaced the battery in my JetPack. The connector does NOT slide out towards the wires; instead, use the tweezers to gently grasp all of the wires, and then lift them straight up and away from the unit.
Reattach the new battery by locating the connector over the receptacle, and push the connector straight down into place. Replace the yellow tape, and reassemble the unit. This worked for me! I hope it helps others.
Mike A. - 04 April, 2019
You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
For a mere $27 get a nearly matching battery. Amazon ASIN B01E0SEXS2
a good condition jetpack on ebay is $17.
Altre 6 persone hanno completato questa guida.
5Commenti sulla guida
I'd like to let you know that after step 9, it is possible to unwrap the battery and break loose the circuit board on the battery. At which point you can reinstall the circuit board in the router with no battery attached. This makes the Jetpack plug-in only which is all I need it for anyways. It was a great and free fix for my swollen battery.
Thanks for the article!
Opps, I think that steps 3 & 4 have been reversed. You can't get to the "3 additional screws" until you're looking at the red cover which is below the black cover that needs to be pried off first.
Otherwise, the process seems to be going well.
It’s unclear. Once you unscrew that first screw, you have to remove the TOP black portion (the picture looks like you’re removing the bottom). Once you remove that top portion, the red plastic is exposed, revealing the three other screws.
And -- continuing with step 5, there are some plastic "snap" locks between the red and black covers -- 5 by my count, 2 along each of the long edges, 1 along the charging port edge. Always good to pry carefully.
Once apart, battery is on bottom and can be easily removed/replaced as per steps 7 & 8.
now how do we FORCE a factory data reset without the admin password?
