Salta al contenuto principale
VTech Write and Learn Creative Center Slider Replacement
Philip Zietkowski
Philip Zietkowski e 3 altri collaboratori
Ultimo aggiornamento il February 19, 2024
5 minuti
Facile
Introduzione
Vai al passo 1
The slider is an important aspect for the VTech Write and Learn Creative Center because the slider allows the children to continue to learn by erasing previous work. The following repair guide addresses properly replacing the slider.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, immagine 1 di 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, immagine 2 di 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Slider Replacement, Slider: passo 2, immagine 1 di 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
Conclusione
1Commento della guida
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 477
