Salta al contenuto principale
VTech MobiGo Touch Learning System Screen Replacement
Daniel Kresge
Daniel Kresge e 4 altri collaboratori
Ultimo aggiornamento il August 5, 2024
4 minuti
Moderato
Passi mancanti
Introduzione
Vai al passo 1
This guide shows users how to replace the screen. By first taking the device apart until they can reach the screen so that they can replace it.
Cosa ti serve
Strumenti
Mostra di più…
  1. VTech MobiGo Touch Learning System Screen Replacement, Case: passo 1, immagine 1 di 1
    • Remove the battery covers and the four batteries.
  2. VTech MobiGo Touch Learning System Screen Replacement: passo 2, immagine 1 di 2 VTech MobiGo Touch Learning System Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. VTech MobiGo Touch Learning System Screen Replacement: passo 3, immagine 1 di 2 VTech MobiGo Touch Learning System Screen Replacement: passo 3, immagine 2 di 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: passo 4, immagine 1 di 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. VTech MobiGo Touch Learning System Screen Replacement: passo 5, immagine 1 di 1
    • Remove the three "L" shaped brackets and the spring.
  6. VTech MobiGo Touch Learning System Screen Replacement: passo 6, immagine 1 di 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. VTech MobiGo Touch Learning System Screen Replacement: passo 7, immagine 1 di 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
  8. VTech MobiGo Touch Learning System Screen Replacement, Screen: passo 8, immagine 1 di 1
    • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
  9. VTech MobiGo Touch Learning System Screen Replacement: passo 9, immagine 1 di 1
    • Remove the black tape
  10. VTech MobiGo Touch Learning System Screen Replacement: passo 10, immagine 1 di 1
    • Remove the circuit board from the back of the screen.
    • The circuit board has double sided tape on the back side holding it to the screen.
  11. VTech MobiGo Touch Learning System Screen Replacement: passo 11, immagine 1 di 1
    • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
    mine i don’t know about
    Jesse Eagan - Replica
  12. VTech MobiGo Touch Learning System Screen Replacement: passo 12, immagine 1 di 1
    • Resolder the new screens ribbon cable on the the circuit board.
    • Always be careful when soldering.
Conclusione
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 Guide realizzate
1Commento della guida
mine i droped a rock on so i don’t get it
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 821
