Salta al contenuto principale
VHS Shell Replacement
McKinley Hixon
McKinley Hixon e 2 altri collaboratori
Ultimo aggiornamento il 1 dic 2023
15 - 25 minuti
Moderato
Introduzione
Vai al passo 1
In this guide, you will learn step-by-step instructions on how to replace the broken shell of a VHS tape when it is too broken to work correctly in a VHS player. In doing this repair, you will be able to salvage the tape so that it can be digitized or continue to be watched. No special skills are needed for this repair, with a screwdriver being the only tool used. It is recommended that you cut or rip off any labels on the sides of the tape before beginning, so that it will be easier to take the top half of the shell off.
Cosa ti serve
Strumenti
  1. VHS Shell Replacement, Plastic Shell: passo 1, immagine 1 di 2 VHS Shell Replacement, Plastic Shell: passo 1, immagine 2 di 2
    • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
  2. VHS Shell Replacement: passo 2, immagine 1 di 1
    • Once the screws are out, pull off the front of the VHS shell.
    • Take off any labels on the sides of tape before doing this step.
    • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
  3. VHS Shell Replacement: passo 3, immagine 1 di 2 VHS Shell Replacement: passo 3, immagine 2 di 2
    • Hold down on the white lever.
    • While holding down, carefully take out the reel on the right.
    • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
  4. VHS Shell Replacement: passo 4, immagine 1 di 2 VHS Shell Replacement: passo 4, immagine 2 di 2
    • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
    • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
  5. VHS Shell Replacement: passo 5, immagine 1 di 1
    • Once the screws are out, pull off the front of the replacement shell.
  6. VHS Shell Replacement: passo 6, immagine 1 di 1
    • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
    • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
    The tape goes up to the left of the plastic piece and to the right of the metal piece, then over to the left
    Marc Margulis - Replica
  7. VHS Shell Replacement: passo 7, immagine 1 di 1
    • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
    The tape goes over the large metal piece then down between the triangle and the small metal piece.
  8. VHS Shell Replacement: passo 8, immagine 1 di 1
    • Turn the reels to retract any excess tape hanging out of the top.
    • This isn't a necessary step, just one that I prefer to do.
  9. VHS Shell Replacement: passo 9, immagine 1 di 1
    • Place the top of the replacement shell back on.
  10. VHS Shell Replacement: passo 10, immagine 1 di 1
    • Screw the screws back in with a screwdriver.
Conclusione
2Commenti sulla guida
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - Replica
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 65
Tutti i Tempi: 2,451
