Salta al contenuto principale
Upgrading  Memory
Upgrading Memory
Clint Sorensen
Clint Sorensen e 4 altri collaboratori
Ultimo aggiornamento il March 7, 2023
5 minuti
Facile
Introduzione
Vai al passo 1
The Brother HL-5240 printer comes standard with 16 megabytes of memory. The following steps can be followed to add more memory. Up to 528 MB of ram can be added.
  1. Upgrading  Memory, Memory: passo 1, immagine 1 di 2 Upgrading  Memory, Memory: passo 1, immagine 2 di 2
    • Flip the power switch to the off position by pressing the side of the button with an "O" symbol.
    • Unplug the printer's cord from the wall socket.
  2. Upgrading  Memory: passo 2, immagine 1 di 3 Upgrading  Memory: passo 2, immagine 2 di 3 Upgrading  Memory: passo 2, immagine 3 di 3
    • Locate the small removable panel on the left side of the printer.
    • Press the tab at the top of the panel.
    • Pull the panel open.
    • Pull the old RAM out of its slot and insert the new RAM in its place.
Linea Traguardo
Cal Poly, Team 4-14, Forte Winter 2010 Membro di Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Membri
10 Guide realizzate
1Commento della guida
I want a way to treat the blurry picture
mahmoud22365 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,661
