Salta al contenuto principale
Udi Discovery U818A FPV Controller Battery Replacement
Raghda Al-Hmeyrat
Raghda Al-Hmeyrat e 4 altri collaboratori
Ultimo aggiornamento il May 24, 2019
5 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to replace the battery of your Udi U818A FPV drone controller. You will need a JIS #0 screwdriver to complete this task.
Cosa ti serve
  1. Udi Discovery U818A FPV Controller Battery Replacement, Controller Battery: passo 1, immagine 1 di 1
    • Turn the remote control over so that the buttons and joysticks are facing downward.
  2. Udi Discovery U818A FPV Controller Battery Replacement: passo 2, immagine 1 di 1
    • Using a JIS #0, unscrew the silver 4mm screw that holds the battery cover in place.
  3. Udi Discovery U818A FPV Controller Battery Replacement: passo 3, immagine 1 di 1
    • Open the battery access panel.
    • Disconnect the red and black wires.
    • Remove the depleted battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 287
