Strumenti
Parti
Nessuna parte richiesta.
Facing your bike, straddle your front wheel between your knees.
Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
In reassembling the wheel to the bike, perform the steps in reverse order.
With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
Squeeze the brake calipers together and return the cable noodle back into the holder.
Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
Slowly peel back the layer of rubber that covers the 32 screws on the tire .
To reassemble your wheel after following steps #4, and #5 simply reattach the rubber tire.
