Salta al contenuto principale
Trek 820 Handlebars Replacement
Kaveh Karimiyanha
Kaveh Karimiyanha e 10 altri collaboratori
Ultimo aggiornamento il November 13, 2020
5 minuti
Facile
Foto Azione
Introduzione
Vai al passo 1
Use this guide to remove the handlebar and stem from a Trek 820 or similar bikes that have a thread less stem.
The stem acts with the handlebar to steer the bike in the desired location while keeping the fork and headset attached to the bikes frame. It is important that these steps are done correctly to ensure that the rider is safe while operating this bicycle.
Before using this guide make sure you have the correct size handlebar and stem depending on which item you are replacing.
Cosa ti serve
Strumenti
  1. Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, immagine 1 di 2 Trek 820 Handlebars Replacement, Handlebar and stem: passo 1, immagine 2 di 2
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: passo 2, immagine 1 di 1
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: passo 3, immagine 1 di 2 Trek 820 Handlebars Replacement: passo 3, immagine 2 di 2
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
  4. Trek 820 Handlebars Replacement: passo 4, immagine 1 di 2 Trek 820 Handlebars Replacement: passo 4, immagine 2 di 2
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: passo 5, immagine 1 di 1
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
Conclusione
Cal Poly, Team 1-1, Propen Fall 2012 Membro di Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Membri
9 Guide realizzate
Un commento
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 5,974
