Trek 4300 Bicycle Kickstand Replacement
Introduzione
Vai al passo 1The kickstand has three parts: a bracket, a bolt, and the stand. To replace the kickstand the bracket and bolt will need to be removed to allow for the removal of the stand.
Cosa ti serve
Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
Once the bolt is loose, unscrew it the rest of the way by hand.
Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
To replace the new kickstand, follow these instructions in reverse order.
