Salta al contenuto principale
Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement
Luis Juen Baez
Luis Juen Baez e 4 altri collaboratori
Ultimo aggiornamento il January 3, 2024
30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to replace the CPU fan and heat sink of the Toshiba Tetra Z50-A.
The CPU fan blows and pulls air off the CPU, keeping it from over heating. This replacement may be needed to fix issues such as overheating, frequent crashing, error messages, or your device making unusual or loud noises. In some cases the CPU can be damaged or broken. Before using this guide, check the trouble shooting page for any other issues that might cause similar problems.
Keep in mind for this guide you will need to know how to apply Thermal Paste to your device. Make sure to completely power of the device and disconnect any power sources before starting this guide.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, Back Panel: passo 1, immagine 1 di 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 2, immagine 1 di 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, Battery: passo 3, immagine 1 di 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 4, immagine 1 di 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 5, immagine 1 di 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 6, immagine 1 di 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 7, immagine 1 di 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, CPU Fan and Heat Sink: passo 8, immagine 1 di 1
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 9, immagine 1 di 1
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 10, immagine 1 di 1
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 11, immagine 1 di 1
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: passo 12, immagine 1 di 1
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
Conclusione
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Membro di UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 23
Tutti i Tempi: 506
