Salta al contenuto principale
Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement
Aniketh Bhat
Aniketh Bhat e 3 altri collaboratori
Ultimo aggiornamento il April 13, 2017
Nessuna stima
Facile
Introduzione
Vai al passo 1
Installing a new Wi-Fi card can improve your internet connection speed as well as maintain a reliable connection. First we will open the back of the laptop. After, we can easily unscrew and remove the Wi-Fi card.
Cosa ti serve
  1. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement, Wi-Fi/Bluetooth Card: passo 1, immagine 1 di 2 Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement, Wi-Fi/Bluetooth Card: passo 1, immagine 2 di 2
  2. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement: passo 2, immagine 1 di 1
    • Locate the Wi-Fi/Bluetooth card, and remove the two wires connected to the card with your hands.
  3. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement: passo 3, immagine 1 di 1
    • Unscrew the single 2.5x6mm holding down the card onto the board with your Philips #0 screwdriver.
  4. Toshiba Satellite P55-A5312 Wi-Fi/Bluetooth Card Replacement: passo 4, immagine 1 di 1
    • Remove/unhinge the card from the board by gently lifting it upwards.
    • Replace it with your new card.
Conclusione
Aniketh Bhat
Membro da: 01/25/17
216 Reputazione
2 Guide realizzate
Cal Poly, Team 9-1, Banghart Winter 2017 Membro di Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,715
