Salta al contenuto principale
Toshiba Satellite P55-A5312 Disassembly
Cosa ti serve
  1. Toshiba Satellite P55-A5312 Disassembly, Toshiba Satellite P55-A5312 Disassembly: passo 1, immagine 1 di 2 Toshiba Satellite P55-A5312 Disassembly, Toshiba Satellite P55-A5312 Disassembly: passo 1, immagine 2 di 2
    • Locate all rubber plugs on the bottom of the laptop. These will need to be removed with a pointed object like the Spudger.
  2. Toshiba Satellite P55-A5312 Disassembly: passo 2, immagine 1 di 1
    • After all rubber plugs are removed, use a Phillip's head screw driver to unscrew all previously covered screws.
  3. Toshiba Satellite P55-A5312 Disassembly: passo 3, immagine 1 di 2 Toshiba Satellite P55-A5312 Disassembly: passo 3, immagine 2 di 2
    • After all screws have been removed, pry the bottom cover of your laptop starting at the front edge.
    • Slowly work your way around the laptop until the back cover is completely off.
Conclusione
Cal Poly, Team 9-1, Banghart Winter 2017 Membro di Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,021
