Salta al contenuto principale
Toshiba Satellite P205-S8811 Hard Drive Replacement
Andrew Meyer
Andrew Meyer e un altro collaboratore
Ultimo aggiornamento il March 17, 2014
10 minuti
Facile
Necessarie Immagini Migliori
Foto Azione
Introduzione
Vai al passo 1
If your hard drive is malfunctioning or if you want to replace it, this guide will show you how to take it out.
Cosa ti serve
Strumenti
  1. Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 2, immagine 1 di 2 Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
  4. Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Place one finger under the tab of the hard drive panel and lift up with medium force.
  5. Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 5, immagine 1 di 2 Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Hold the black tab attached to the hard drive and pull with medium force to the side that the tab is on. This will pull the hard drive out of it's socket.
  6. Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 6, immagine 1 di 2 Toshiba Satellite P205-S8811 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Use a #1 Phillips screwdriver to unscrew the four 4mm Phillips #1 screws (2 on each side) holding the brackets to the hard drive.
    • With the screws undone, the brackets should come right off. Next, pull on the black tab again to pull the cover off of the hard drive.
Conclusione
Andrew Meyer
Membro da: 02/03/14
245 Reputazione
2 Guide realizzate
Cal Poly, Team 2-8, Amido Winter 2014 Membro di Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Membri
7 Guide realizzate
Un commento
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
Robert Cartier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,133
