Toshiba Satellite L855-S5210 LCD Screen Replacement
Cosa ti serve
So, your spouse fell on your computer while taking a nap... let's replace the LCD. I got mine from http://www.LaptopScreen.com
First, here's some tools you might consider using while working. You may also want an old credit card of your choosing to help get inside. More on that later.
Remove the plastic covering that encloses the Hard Drive and RAM. This is done by loosening (not removing) a single screw on the large plastic piece.
After removal, there are 4 screws under the plastic we need to remove. See the image to locate them all. Place them in your screw organizer.
Carefully tug the LCD cable out from under the motherboard.
Make sure that the LCD cable is fully seated before you finish up. Use a light to double check it. I had to take the PC apart 4 times till I found out the cable wasn't in the socket but underneath it.
Check out your screw collection. This is roughly what yours should look like if you're keeping track of them.
Finally, bust out your new LCD screen that you should have purchased from www.laptopscreen.com, and reverse the entire procedure for installation.
-- Final Notes and Credits: Difficulty Level: Medium. | Screen purchased from: www.laptopscreen.com (their email support will land you a compatible screen within hours!) | We are The PC Penguin, www.thepcpenguin.com
Altre 2 persone hanno completato questa guida.
4Commenti sulla guida
Steps 3 - 16 are not needed to remove the screen. Should take about 10 minutes. Reverse to install.
Hey there, thanks for this guide. I own a Satellite L855-17z. The architecture seems very similar to me. Do you think I can follow this guide for my model ?
I made a huge bump in the middle of the screen's hood. Luckily, it's barely affected the screen, minus for a tiny little spot of white pixels where the hood is pressing on the screen. I just want to remove my screen to flaten the bump.
English isn't my native language, so sorry for any odd sentence or badly used vocabulary.
Yeah, she "feel on it". What she actually was doing was using it as a desk to STAPLE PAPERS on top of. After you told her three times to sit up and do her work, because setting up camp in the recliner was how she stupidly ruined the USB socket, and the two more times you dug out that shorted socket so the sad thing would start. So while you know ultimately your're just whizzing in the wind; you still gotta thank that ifixit guy (THNX!) for that brief moment when you're a dang "IT professional"! Or something, you don't really know what that means.
I used this guide to replace the LCD (and clean the fan) on an old L855-S5405, and it worked like a charm! Except the reverse of Step 13 was a pain in the neck as expected, lol. Thanks so much for this guide!
