Salta al contenuto principale
Toshiba Satellite A210 Keyboard Replacement
Youlen
Youlen e 12 altri collaboratori
Ultimo aggiornamento il January 21, 2025
5 - 10 minuti
Moderato
Inconveniente Markup
Necessarie Più Immagini
Introduzione
Vai al passo 1
In this guide you will learn how to remove a keyboard safely. Before you begin this guide you should have all required materials and tools necessary to properly remove the keyboard.
Cosa ti serve
Strumenti
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Toshiba Satellite A210 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: passo 2, immagine 1 di 2 Toshiba Satellite A210 Keyboard Replacement: passo 2, immagine 2 di 2
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: passo 4, immagine 1 di 3 Toshiba Satellite A210 Keyboard Replacement: passo 4, immagine 2 di 3 Toshiba Satellite A210 Keyboard Replacement: passo 4, immagine 3 di 3
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: passo 5, immagine 1 di 2 Toshiba Satellite A210 Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: passo 6, immagine 1 di 1
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Youlen
Membro da: 04/11/13
49 Reputazione
2 Guide realizzate
Cal Poly, Team 17-5, Regan Spring 2013 Membro di Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
4 Membri
18 Guide realizzate
1Commento della guida
very useful. THANKS
ANDREAS - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,681
