Salta al contenuto principale
Three-way Switch Replacement
Tao Zhuo
Tao Zhuo e 5 altri collaboratori
Ultimo aggiornamento il 26 ott 2023
20 - 45 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
A three-way switch is a common type of light switch that is used in many homes to control a single light fixture from two or more locations. Over time, these switches may become worn or damaged, requiring replacement.
Replacing a three-way switch may seem like a daunting task, but with the right tools and instructions, it can be a simple DIY project. In this guide, we will provide step-by-step instructions on how to replace a three-way switch safely and effectively.
Whether you are a seasoned DIYer or new to home repairs, this guide will give you the confidence and knowledge you need to replace a three-way switch and restore proper functionality to your lighting system.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Three-way Switch Replacement, Three-way Switch: passo 1, immagine 1 di 2 Three-way Switch Replacement, Three-way Switch: passo 1, immagine 2 di 2
    • Locate and turn off the circuit breaker for your switch.
    • Try to turn the switch to ensure you turned the power off.
  2. Three-way Switch Replacement: passo 2, immagine 1 di 1
    • Use the screwdriver to remove the 15mm Flathead screws on the wall plate.
    • Remove the wall plate from the wall.
  3. Three-way Switch Replacement, Determine voltage absence: passo 3, immagine 1 di 2 Three-way Switch Replacement, Determine voltage absence: passo 3, immagine 2 di 2
    • While wearing insulated gloves, gently pull out the switch and use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
    • You can also use a single pole phase tester, but that's not the proper way to do it.
    • Do not work on live circuits if you are not an experienced professional.
  4. Three-way Switch Replacement: passo 4, immagine 1 di 3 Three-way Switch Replacement: passo 4, immagine 2 di 3 Three-way Switch Replacement: passo 4, immagine 3 di 3
    • Label the black live or load wire which connects to the power or the device and usually on the down position of the switch.
    • Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch.
  5. Three-way Switch Replacement: passo 5, immagine 1 di 2 Three-way Switch Replacement: passo 5, immagine 2 di 2
    • Label the two traveler wires where the up position is held by gold screws of the old switch.
  6. Three-way Switch Replacement: passo 6, immagine 1 di 3 Three-way Switch Replacement: passo 6, immagine 2 di 3 Three-way Switch Replacement: passo 6, immagine 3 di 3
    • Use the screwdriver to loosen the 5mm Phillips #1 screws so that you can remove these two traveler wires.
    • After the wires are removed, disconnect the old switch.
  7. Three-way Switch Replacement: passo 7, immagine 1 di 2 Three-way Switch Replacement: passo 7, immagine 2 di 2
    • You will find there are one or two wires left in the outlet box.
    • Ground wire is the bare copper wire.
    • The white one is the neutral wire that may be in another outlet box.
    • Please label the neutral wire and the ground wire.
  8. Three-way Switch Replacement: passo 8, immagine 1 di 3 Three-way Switch Replacement: passo 8, immagine 2 di 3 Three-way Switch Replacement: passo 8, immagine 3 di 3
    • Using your new switch, link two traveler wires to the positions with gold screws of the new switch and tighten the 5mm Phillips #1 screws.
    • Link the live or load wire to the position with a black screw and tighten the 5mm Phillips #1 screw.
    • Please ensure you link the wires to the correct places.
  9. Three-way Switch Replacement: passo 9, immagine 1 di 2 Three-way Switch Replacement: passo 9, immagine 2 di 2
    • If there is a green 5mm Phillips #1 screw on the new switch, please link the ground wire to and tighten it.
    • For the intelligent switch, there would be a green wire so that you can group the ground wire with the green wire and tighten them with a wire nut.
  10. Three-way Switch Replacement: passo 10, immagine 1 di 2 Three-way Switch Replacement: passo 10, immagine 2 di 2
    • There is an extra white wire on the intelligent switch.
    • Group the neutral wire with the white wire and use the wire nut to tighten them.
  11. Three-way Switch Replacement: passo 11, immagine 1 di 3 Three-way Switch Replacement: passo 11, immagine 2 di 3 Three-way Switch Replacement: passo 11, immagine 3 di 3
    • Turn the power on and check whether the new switch works.
    • Gently push the wires back into the outlet box.
    • You’ll also need to leave some space for the switch.
    • Secure the new switch with the 10mm Phillips #1 screws.
    • Finally, secure the wall plate.
Conclusione
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,032
