Salta al contenuto principale
The Claw  "Claw" Replacement
Alain Pierre
Alain Pierre e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
If you are experiencing trouble with the claw or it does not seem to be opening or closing properly, it is possible that the claw itself is broken or damaged. This requires the user to open the claw device in order to access the mechanical claw. Follow this easy guide in order to properly and easily replace your claw.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. The Claw  "Claw" Replacement, Top Cover: passo 1, immagine 1 di 1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw  "Claw" Replacement: passo 2, immagine 1 di 1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw  "Claw" Replacement: passo 3, immagine 1 di 1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw  "Claw" Replacement: passo 4, immagine 1 di 1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw  "Claw" Replacement: passo 5, immagine 1 di 1
    • Remove the top cover of The Claw machine.
  6. The Claw  "Claw" Replacement: passo 6, immagine 1 di 2 The Claw  "Claw" Replacement: passo 6, immagine 2 di 2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw  "Claw" Replacement: passo 7, immagine 1 di 1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw  "Claw" Replacement, Claw: passo 8, immagine 1 di 1
    • Once you have removed the top cover of the claw you can easily access the claw and you will see that the claw is attached by two small chains.
    • Locate the small rings that attach the chain to the plastic claw.
  9. The Claw  "Claw" Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
    • Replace the claw one ring at a time. The chain needs to be attached to the new claw in the same configuration. One side of the chain opens the claw and the other side is just a hanging support.
    My claw machine has only one of the chains attached when I opened the box. The claw does not open because that chain is not attached.
    Ronnie Crumpton - Replica
    Addition to the above comment. The open chain is not attached to the gear box.
Conclusione
Altre 2 persone hanno completato questa guida.
Alain Pierre
Membro da: 03/22/16
1.188 Reputazione
9 Guide realizzate
6Commenti sulla guida
Where do I buy a new grabber thing
Oliver Chew - Replica
The 1st joystick that moves the claw forward and back doesn’t work.
Michelle Bianchini - Replica
What if the chain won't go down as it deep as it used to be?
Mira DIP - Replica
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
Greg Sturges - Replica
My chain fell off and I dont know how to fix
Kathellyn Da silva - Replica
Porque la garra no sube ni baja +?
Pero a los lados si funciona!?
Gracias
BB᭄ᎷᎪQᎠᎬҒႮᎬ Bᴀʀʀɪᴏ᭄Bʀᴀᴠᴏ - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 58
Tutti i Tempi: 10,087
