Salta al contenuto principale
Summer 3D Lite Convenience Stroller Front Wheel Replacement
Tyler Haugland
Tyler Haugland e 4 altri collaboratori
Ultimo aggiornamento il November 7, 2017
2 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to replace the front wheels on your Summer Infant 3D Lite stroller.
  1. Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: passo 1, immagine 1 di 2 Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: passo 1, immagine 2 di 2
    • Locate the black plastic tabs on the front wheel. There should be two, opposite sides from each other.
    Where can I just order the front wheel? The metal piece that goes in between the two wheels is bent and it will not roll right.
    joanna28146 - Replica
    Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST
    Stroller Guy -
    Puse las ruedas al reves y ahora no puedo sacarlas para ponerlas correcto ,que puedo hacer Ayuda
    Isabel Mtz - Replica
    Me pasó lo mismo, coloqué las ruedas al revés y hice lo que dice aquí, busque los 2 que me mantiene la rueda dentro los empuje con la llave de casa y logre retirarla
    penelope Medina Rosa -
    I wish it was easy! My tabs will not push it, we have tried everything.
    Bojones - Replica
    I put the front wheel o wrong..how can i get it off.. Its upside down?
    Alicia Cox - Replica
    Did you get it off?
    Ron Hossannah -
  2. Summer 3D Lite Convenience Stroller Front Wheel Replacement: passo 2, immagine 1 di 2 Summer 3D Lite Convenience Stroller Front Wheel Replacement: passo 2, immagine 2 di 2
    • Firmly press both tabs inwards, and use your other hand to pull the wheel off
    How can i orther the front wheels
    Amalia Ontiveros - Replica
    Stroller Guy -
    It is really to press the two tabs, and pull at the same time???
    Any help plz will be appreciated.
    lenati02 - Replica
    Is not easy to to all that, these tabs are very hard
    noreima D -
    We have the arrow pointing the down but now we can’t get the front wheel off. It’s stuck and we can’t seem to push both tabs down. This feels impossible!
    Amie Lamie7574 -
    If you use an adjustable wrench, it’s easy to push in the tabs. Set the opening just slightly larger than the diameter of the round piece and push in.
    Dadwillfixit -
    Thank you so so much. I fixed it.
    Priya - Replica
    Just as the other customer said once you put it on wrong. The front wheel it is impossible to get off. I caught a hand cramp trying to pull that industrial strength locking system. Plzzzz help its crooked.
    Toshina Kitt - Replica
    Use an adjustable wrench - set it slightly larger than the round part and push against both tabs at the same time.
    Dadwillfixit - Replica
    My tabs will not push it at all!
    Bojones - Replica
    We used two metal spoons to press the buttons while pulling wheel off. It worked.. Lol..
    Nijamudheen A - Replica
    Puse las ruedas delanteras mal ahora nose como sacarla ayuddaaaa
    Hdbshs - Replica
    I’m trying to return this stroller and now I know the reason they make these wheels so impossible to remove. so I can’t return! My fingers feel like they are bleeding. I’ve tried pliers, a wrench, & scissors, and nothing pushes the tabs in enough for me to pull the wheel off (and my wheels are on correctly). This is another reason why more expensive strollers are soooooo worth it!! One simple button and the wheels come off my uppababy :)
    Christine Barr - Replica
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team 11-5, Forte Fall 2015 Membro di Cal Poly, Team 11-5, Forte Fall 2015
CPSU-FORTE-F15S11G5
4 Membri
3 Guide realizzate
15Commenti sulla guida
How can i order the front wheels
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST.
Stroller Guy -
I think there should be a video tutorial for this product. thank you!!
Lisa D. Richards - Replica
Yes i think there should be a video
yummy mummy fantom XXX -
The Front wheel is less bending in the axis, how to make straight by hand
Samson Wong - Replica
How do I do this if I put the wheels in the wrong way? I can see the tabs but I can’t grip enough of it.
Martha Andama - Replica
I have the same issue. One wheel has the arrow down. I cant seem to get the wheel off.. please help
rob barnard - Replica
I'm having the same issue with the front wheel being installed upside down and tabs are very hard to push in to unlock.
Marissa - Replica
copied from a very helpful FB post I found after installing the wheel upside down: “I also did the same thing the little black tabs are near the break lever you use the break leaver with one of the black tabs to hold it down and then I used my flat head screw driver to push the other tab down... Only then was I able to pop the front wheel off because you have to pinch both black tabs at the same time to get it off. Hope this helps and good luck!”
Melissa M Smith - Replica
Is there a video for this
yummy mummy fantom XXX - Replica
No video but if you follow my instructions you should get it off.
Life Andrews -
Ok so it isnt as easy at first, once you see what you need to click, it will come right off. If you look at step 1 you will see what tab you need to press. That same clip is also on the opposite side of the the example. You definitely need 2 flat head screwdrivers to get it off. It's no way to get it off with just your fingers. So you need one flat head to push in the 1st tab, then turn the stroller over and use the 2nd flat head to push in the 2nd tab. The wheel should slide off. Good luck. Hope it helps
Life Andrews - Replica
What to do if a front wheel is wobbling as we stroll..?
Not sure what happened to cause this but the metal bar in the middle of wheel looks bent and making wheel wobble.
AskingForAFriend - Replica
Hi,
I need a pair of these front wheels, based in South Africa. Please advise cost and shipping.
vasienair29@gmail.com
Vas Nair - Replica
This is impossible
Katie Fernandes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 100
Ultimi 30 Giorni: 300
Tutti i Tempi: 58,508
