Salta al contenuto principale
Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement
Benjamin J Farland
Benjamin J Farland e 3 altri collaboratori
Ultimo aggiornamento il January 2, 2024
30 minuti
Moderato
Introduzione
Vai al passo 1
This guide shows you how to replace the two activations buttons for the Sublue WhiteShark Mix Underwater Scooter.
  1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Top Floater Removal: passo 1, immagine 1 di 1
    • Remove the black screw by rotating it counterclockwise.
  2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 2, immagine 1 di 1
    • Hold the device in place and pull up on the floater.
  3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the top floater.
  4. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Battery: passo 4, immagine 1 di 1
    • Turn the device upside-down.
  5. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 5, immagine 1 di 1
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
  6. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 6, immagine 1 di 1
    • A push tab holds the battery in.
  7. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 7, immagine 1 di 1
    • Push the tab in and pull the battery outward to remove it.
  8. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Lower Panel: passo 8, immagine 1 di 1
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
  9. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 9, immagine 1 di 1
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
  10. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Activation Buttons: passo 10, immagine 1 di 1
    • There are two action buttons on each side of the main body.
  11. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 11, immagine 1 di 1
    • Push on the top outer corner of each action button to pop them out of place.
  12. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: passo 12, immagine 1 di 1
    • After each action button is released, pull outward to remove.
Conclusione
1Commento della guida
Mine have corroded, do you know where I can get x2 replacement activation buttons or just the circular discs??
AMW - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 162
