Spin Master Boxer Robot Battery Replacement
Introduzione
Vai al passo 1If Robot’s internal battery does not hold a charge, follow this guide to replace the battery. You will need a Size 00 Philips Screwdriver to complete replacement guide.
Cosa ti serve
Strumenti
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
Lift the top panel away from the main body of the robot to expose the yellow battery.
Insert index finger in between battery and plastic shell of robot, and push battery out of the battery holder toward the wire.
Does anyone know the battery specs? It seems to be a 3.7V LiPo but it would be nice to know the mAh rating and size (usually something like 500mAh and 703535) before opening the Boxer so that you can proceed with the replacement after removing the old battery.
I don’t, but were you able to find out after opening and replacing it? Thanks!
I just ordered a replacement battery with same power specs and a size that would fit the slot. I'll update when I install and let you know if it
The battery is indeed a 3.7v/500 mah lipo battery according to the boxer manual. I bought a replacement Amazon with dimensions to fit in the slot, but after troubleshooting discovered that it was my charging port, not battery that was faulty. I'm looking into resoldering a new port to get him working again.
The charging port is difficult to replace. To be able to put it back you will need to de-solder the PCBs that were soldered together. They are interlocked to each other like a box. It would be so much easier to replace if the charging port was put upside down as you can solder it back without de-soldering the PCBs.
cdtj926 -
Altre 2 persone hanno completato questa guida.
3Commenti sulla guida
Any tips on where to buy a replacement battery?
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
can we replace boxer’s USB slot?
think you i can fix
Darren Davis - Replica
