Sony XPERIA Tablet Z Screen Replacement
Introduzione
Vai al passo 1Use this guide to replace the display on your Sony XPERIA Tablet Z.
This guide will take you through the process of removing the display and connection points to the motherboard.
This will require heating the screen to remove the adhesive be very careful as too much heat can damage the tablet its self.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
Altre 8 persone hanno completato questa guida.
5Commenti sulla guida
Do you need adhesive to attach new screen, & if so, what do you use?
Wooo its self explanatory.Good work
Where do I get the Screen if I'm in South Africa
